can wrong valve adjustment cause smog not to pass??????
Old Sep 27, 2004 | 09:30 PM
eg:R's Avatar
Default can wrong valve adjustment cause smog not to pass??????
i have a 97 civic lx, i have set the valves to 6 intank and 7 exhast, it does not sound so good, but will it cause it to fail smog????
Old Sep 27, 2004 | 10:08 PM
Luserkid's Avatar
Default Re: can wrong valve adjustment cause smog not to pass?????? (jacklee)
What do you mean you set 6 to intake and 7 to exhaust?
oh did you mean .006 and .007?
I think you could fail for not having your valves right, because the it could be leaking exhaust or something. Im probably wrong but i know that valve adjustments can help you on smog, just dont know why.
Old Sep 28, 2004 | 08:53 AM
BatuKing's Avatar
Default Re: can wrong valve adjustment cause smog not to pass?????? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I think you could fail for not having your valves right, because the it could be leaking exhaust or something. </TD></TR></TABLE>
yes you will get high NOX due to no valve overlap, adjust them to specs
Old Sep 29, 2004 | 10:29 PM
eg:R's Avatar
now i am throwing a code, it saids 67, anyone knows what that is exactly???
Old Sep 30, 2004 | 11:15 AM
Gomez_Si's Avatar
Default Re: (jacklee)
I think thats the 2nd O2 sensor. Do you have your CAT on? Usually goes on when you take it off. My book just says Catalyst Efficiency below level. Meaning CAT is not doing what it's suppose to be doing.
Old Oct 2, 2004 | 09:53 AM
eg:R's Avatar
Default Re: (Gomez_Si)
yes the cat. is still on, it used to come on once in a while and i used to reset it from the battery, every thing is stock,
garyhgaryh
May 14, 2013 07:24 PM
sirrjibbalott
Jul 24, 2006 10:05 PM
0bLiViOuS
Jun 30, 2005 02:35 AM
Matgallis
Jan 26, 2005 06:04 PM
