can wrong valve adjustment cause smog not to pass??????
Old 09-27-2004, 09:30 PM
Default can wrong valve adjustment cause smog not to pass??????
i have a 97 civic lx, i have set the valves to 6 intank and 7 exhast, it does not sound so good, but will it cause it to fail smog????
eg:R is offline
Old 09-27-2004, 10:08 PM
Luserkid's Avatar
Default Re: can wrong valve adjustment cause smog not to pass?????? (jacklee)
What do you mean you set 6 to intake and 7 to exhaust?
oh did you mean .006 and .007?
I think you could fail for not having your valves right, because the it could be leaking exhaust or something. Im probably wrong but i know that valve adjustments can help you on smog, just dont know why.
Luserkid is offline
Old 09-28-2004, 08:53 AM
BatuKing's Avatar
Default Re: can wrong valve adjustment cause smog not to pass?????? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I think you could fail for not having your valves right, because the it could be leaking exhaust or something. </TD></TR></TABLE>
yes you will get high NOX due to no valve overlap, adjust them to specs
BatuKing is offline
Old 09-29-2004, 10:29 PM
now i am throwing a code, it saids 67, anyone knows what that is exactly???
eg:R is offline
Old 09-30-2004, 11:15 AM
Gomez_Si's Avatar
Default Re: (jacklee)
I think thats the 2nd O2 sensor. Do you have your CAT on? Usually goes on when you take it off. My book just says Catalyst Efficiency below level. Meaning CAT is not doing what it's suppose to be doing.
Gomez_Si is offline
Old 10-02-2004, 09:53 AM
Default Re: (Gomez_Si)
yes the cat. is still on, it used to come on once in a while and i used to reset it from the battery, every thing is stock,
eg:R is offline
jwarren1904
06-12-2013 03:24 AM
garyhgaryh
05-14-2013 07:24 PM
sirrjibbalott
07-24-2006 10:05 PM
0bLiViOuS
06-30-2005 02:35 AM
Matgallis
01-26-2005 06:04 PM
Quick Reply: can wrong valve adjustment cause smog not to pass??????
  • Ask a Question
Question Title:
Description:
