chop saw for collector cutting?
Old Sep 27, 2004 | 06:45 PM
self_made's Avatar
Default chop saw for collector cutting?
Anyone use a chopsaw to cut collectors? will it work and come out decent on sch40 piping?
Old Sep 27, 2004 | 06:52 PM
brokeasscrix's Avatar
yes it will! just use a debur to remove the excess kerf on the inside of the pipe!
Old Sep 27, 2004 | 07:00 PM
self_made's Avatar
Default Re: (brokeasscrix)
does anyone have any pictures of one cut with a chop saw to see what im gonna have to deal with? thanks
Old Sep 27, 2004 | 09:24 PM
FyReo3's Avatar
Default Re: (VTECNLUDE)
It can be done, that is all I had. You have to go slow, the blade will flex causing uneven cuts. I cut it close enough, then used a belt sander to make them even.
Old Sep 27, 2004 | 11:07 PM
SMSP's Avatar
Default Re: chop saw for collector cutting? (VTECNLUDE)
I bought a Milwaukee chop saw a few years ago and tried it for 18g and 16g tubing and it wasn't as clean as I hoped. But with the pipe you are using it may be better. BTW, I want to sell it to make space. If you are interested please email me at the address below.
Old Sep 27, 2004 | 11:42 PM
Ekasey's Avatar
Default Re: chop saw for collector cutting? (SMSP)
we use a band saw
Old Sep 28, 2004 | 04:49 AM
HamiltonRex's Avatar
Default Re: chop saw for collector cutting? (eLusive ek4)
Bewo saw and nothing but!
Chop saw will work, there messy and if you want say a 90Deg cut you will be +/- 5deg
Old Sep 28, 2004 | 07:01 AM
SiRex91's Avatar
Default Re: chop saw for collector cutting? (HamiltonRex)
I used a chop saw for making downpipes and intercooler piping. It requires a decent amount of time with needle files and with a beltsander in order to get all the kerf off the piece of tubing. Also, my cuts weren't 100% accurate if they were something other than a straight 90deg cut.
Back in my welding class we used a horizontal bandsaw to cut tubing and it would get perfect clean cuts everytime (basically no cleanup at all)
Old Sep 28, 2004 | 07:09 AM
legendboy's Avatar
Default Re: chop saw for collector cutting? (SiRex91)
Oh man, trying to make nice collectors, with repeatable results on a chop saw would be brain damage!
Old Sep 28, 2004 | 12:52 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">we use a band saw</TD></TR></TABLE>
ditto
but will probably be going to a cold saw
Old Sep 28, 2004 | 03:51 PM
legendboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
ditto
but will probably be going to a cold saw</TD></TR></TABLE>
I also have a cold cut saw at work and I don't have much luck cutting much except 90 degree cuts on straight tubing. Ours comes down with such force that the blade almost always flexes when it hits something angled. I tried for many hours to no avail. It would have been soooooo nice to use it as I could have cut an entire collector in about 30 seconds!
Old Sep 28, 2004 | 07:16 PM
matt_sb2000's Avatar
Default Re: chop saw for collector cutting? (legendboy)
I use our cold saw for stuff like that all the time.
Sharp blade, and a proper chip load are what's important with that.
Tigfab
Welding / Fabrication
Aug 21, 2006 05:17 AM
criitter7
18
Mar 26, 2006 07:19 PM
Superorb
16
Feb 23, 2006 06:18 PM
BlueShadow
Jun 11, 2005 09:32 PM
revhrdls
Sep 27, 2001 06:36 AM
