D15B1 vs. D15B2
Old Sep 27, 2004 | 05:16 PM
johnclaunch's Avatar
Default D15B1 vs. D15B2
What are the differences in the B1 vs. the B2 for one to have 70hp, and the other to have 92hp? Also, do both Dual Point FI cars (STD and DX) have the same ECU (PM5)? Thanks.
Old Sep 27, 2004 | 07:15 PM
Change's Avatar
Default Re: D15B1 vs. D15B2 (johnclaunch)
the b1 has a terrible cam, a turbo like header with a cat right off of it and bad exhaust.
Old Sep 27, 2004 | 09:01 PM
Default Re: D15B1 vs. D15B2 (pSI civic)
Bump.
So if I change the ECU, cam, and put a DX 5-speed on, how much of a performance difference are we looking at?
Old Sep 27, 2004 | 09:13 PM
Donkey85's Avatar
just for your info not all b1's had the cat comming right off the exhaust manifold some came just like the dx style with the cat under the car
Old Sep 27, 2004 | 09:15 PM
Donkey85's Avatar
Default Re: D15B1 vs. D15B2 (Donkey85)
also on the b1s when you floor it the throttle body butterfly only opens 1/2 to almost 3/4's of the way while the b2 it will open all the way
Old Sep 28, 2004 | 05:22 PM
Change's Avatar
the 90-91 had a normal cat and the 88-89 had the header/cat thing.
if you put a new cam, header,exhaust and i guess do something with the tb like that guy just said you can make it into a b2.
why do you need a dx tranny? its not all that special... if you want a good one find an si tranny.
Old Sep 28, 2004 | 05:33 PM
Ass$nyper's Avatar
Pirate General...YARRRR
even a dx tranny beats the STD one but i'll admit i loved my long gears short *** B16 tranny not long at all lol
best bets for a b1 are swap head and tranny or whole damned thing
even with MPFI the cam holds you back alot.
Old Sep 28, 2004 | 05:38 PM
Change's Avatar
Default Re: D15B1 vs. D15B2 (Ace$nyper)
yeah even the b2 cam is a lot better.
Old Sep 28, 2004 | 08:12 PM
importslife's Avatar
Could he not put a si cam in it? I was going to try it. Could it work? I have a D15B non-vtec (no number) in my 91.
Old Sep 28, 2004 | 08:17 PM
Change's Avatar
Default Re: D15B1 vs. D15B2 (importslife)
an a6 cam? i guess it would work...
Old Sep 28, 2004 | 09:29 PM
Donkey85's Avatar
yeah u can but an si cam in it but what for when ur throttle body only opens half way?
Old Sep 28, 2004 | 09:33 PM
sheissrx's Avatar
I'm not trying to be an ******* or anything, but why the hell would you even boter wasting the time on that slow **** when you can just get a zc and a dx tranny? but for the info, dx has 16v head, different ecu, intake manifold/wiring (mp vs. dp), tranny. If you want, i can sell you my stuff.
Old Sep 28, 2004 | 09:42 PM
Donkey85's Avatar
Default Re: D15B1 vs. D15B2 (sheissrx)
b1's are 16 valve also
Old Sep 28, 2004 | 10:46 PM
drussell4801's Avatar
I don't know what the numbers b1 or b2 are,
BUT...
hf is 2 valves per cylinder, multi port(higher compression, too, no joke)
dx is 4 valves per cylinder, dual port
si is 4 valves per cylinder, multi port
si trans shortest gears, then dx, then hf is a distant 3rd.
someone else can inform you about the civics; i have no first-hand experience.
the guy who said don't waste your time was right. You can't make any real difference in performance with these parts. Get a jdm dual cam zc or a single cam vtec, otherwise all you've got is a commuter car.
Old Sep 28, 2004 | 10:59 PM
shocker's Avatar
maybe he's tryin to get some speed on a low budget.......
Old Sep 29, 2004 | 01:31 AM
Default Re: (shocker)
I guess either way he'll be learning.
Old Sep 29, 2004 | 01:51 PM
90-91 hf/dx both came with a D15B2 and some people dont want to change the motor out to gain hp. Some people like to keep it real. i give props to whoever want to to gain out of the factory D-series. i have a friend that works a (Year One) that has a 89si with 186 hp at the wheels out of a D16A6 no nos/turbo/sc all motor
Old Sep 29, 2004 | 02:53 PM
viper_2_4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shocker &raquo;</TD></TR><TR><TD CLASS="quote">maybe he's tryin to get some speed on a low budget.......</TD></TR></TABLE>
there are better ways, even on a budget, if you shop around you can get a d16a6 for dirt cheap(100-150), that will be way better than trying to make a d15b1 into a d15b2.....
Old Sep 29, 2004 | 03:24 PM
DJ_SaNdOz's Avatar
Default Re: (civiccxr)
Don't forget the Chinese D15B2 which is the same as the JDM D15B VTEC. 130ps (128hp)
Old Sep 30, 2004 | 04:18 PM
Donkey85's Avatar
Default Re: (DJ_SaNdOz)
that is the jdm d15b
Old Sep 30, 2004 | 04:25 PM
eumoria's Avatar
Default Re: (Donkey85)
if you do the MPFI swap doesn't that replace the throttle body therefore fixing the 1/2-3/4 opening problem?
And even further then that... it there any way to fix that w/o swapping IMs??
Old Sep 30, 2004 | 04:32 PM
The DX Rex's Avatar
Default Re: (eumoria)
DONT WASTE YOUR TIME WITH IT, swap a sohc vtec or b series, NO point in trying to get performance out of a DPFI. do like i did and throw it in the garbage.
Old Sep 30, 2004 | 06:12 PM
Default Re: (nyhustla2k)
hehe, i just got a picture in my head of the thing sitting out at the curb on trash day
Old Sep 30, 2004 | 08:48 PM
Donkey85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">if you do the MPFI swap doesn't that replace the throttle body therefore fixing the 1/2-3/4 opening problem?
And even further then that... it there any way to fix that w/o swapping IMs??</TD></TR></TABLE>
yes if u were to swap to mpfi it would take car of the whole throttle body issue
i sapose if u were to put the DX throttle body on it would fix that problem too but it really would make that huge of a difference if any
Old May 30, 2008 | 12:36 PM
HONDAD15B1's Avatar
Default Re: D15B1 vs. D15B2 (Change)
so is the d15b1 supposed to be in a 94' civic ex
