What exactly is VTEC?
Old Sep 27, 2004 | 04:22 PM
D3U1LT's Avatar
Default What exactly is VTEC?
I know it stands for Variable Valve Timing with Electronic Lift Control but what does all of that mean?
Old Sep 27, 2004 | 04:25 PM
BoredRec's Avatar
Default Re: What exactly is VTEC? (EJ1Racing.tk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1Racing.tk &raquo;</TD></TR><TR><TD CLASS="quote">I know it stands for Variable Valve Timing with Electronic Lift Control but what does all of that mean? </TD></TR></TABLE>
At low speeds the cams run at a lower cam lobe profile. When you reach a certain RPM, oil pressure builds up and locks the "race cam" which extends the profile of cam.
Old Sep 27, 2004 | 04:46 PM
t0p_sh0tta's Avatar
Default Re: What exactly is VTEC? (BoredRec)
http://www.HowStuffWorks.com - Search for VTEC. Lots of good diagrams and animations
Old Sep 27, 2004 | 04:49 PM
h22vtecmonster's Avatar
variable valve timing and electronic control lift
Old Sep 27, 2004 | 04:50 PM
oops sorry already knew
Old Sep 27, 2004 | 05:02 PM
alloutmotor's Avatar
its really simple, Its a good idea because its economic
Variable Valve timing, which different manufactorers have, but use different combination of letters to define can be simply explained as this
if u know what a camshaft does, it should take no time to register, the cam open and closes the valves, How long it keeps them open is called duration measured in degrees, and how high or far is called lift. measured in mm....
to make big horsepower, u need a good combination of both, but u are going to sacrifice low end power.....you will decrease gas milage and get a loopey idle which most people dont really want from a stock car
so to make it the best of both worlds, Car manufactorers created Variable valve timing...The cam shaft has two different size lobes to open one set of valves, Usually in the order of "Small lobe Big lobe small lobe" when driving around normally the small lobes open and close the valves for economical reasons, when u get the itchy right foot to floor the pedal, if the conditions are right, (car at operating temp, oil pressure ect ect) the car will use oil pressure to engage or activate the bigger cam shaft which will increase the amount of air going into the engine there for more power
thats as simple as i can put it
Old Sep 27, 2004 | 07:00 PM
skunk2eg's Avatar
Default Re: (alloutmotor)
put in short, its keeps the car fuel efficent at lower rpm and when vtec kick in it "kinda" like having a race cam
it's all about cam timing
Old Sep 27, 2004 | 07:33 PM
eda6's Avatar
Nikos
Jan 31, 2007 08:27 AM
T-78RX7
11
Aug 5, 2005 09:28 PM
Chiovnidca
Mar 4, 2004 06:56 AM
zxcv
Feb 11, 2004 05:48 PM
dallasyoung
May 12, 2003 09:12 PM
