manifold question
Old Sep 27, 2004 | 09:40 AM
eg6T's Avatar
Default manifold question
if you sand down the welds on a turbo manifold,would it effect the strength of the manifold?thanks
Old Sep 27, 2004 | 10:52 AM
kb58's Avatar
Banned
Default Re: manifold question (eg6T)
Like most things, it depends. How large the weld is to start with, whether the joint had a "V" ground in it before it was welded (meaning, full penetration.) How much material you remove (it's easy to remove too much and "opps.") And finally is the original welded on both sides of the flange. You're probably find to remove "some" amount for appearance, just stop when it's just enough.
Old Sep 27, 2004 | 11:55 AM
eg6T's Avatar
Default Re: manifold question (kb58)
cool thanks man
numbnuts22715
Jan 16, 2007 03:23 AM
boostdummy
Jan 19, 2006 09:06 PM
SIK IN DA HED
Mar 28, 2004 09:50 AM
88crxvtec
Mar 24, 2004 09:51 AM
Sivik
Mar 18, 2003 08:19 AM
