Use this to convert spring rates (kg--->lbs and lbs---->kg)
Even better, download this... never worry about conversions again.
http://www.joshmadison.com/software/...t/download.asp
I believe he was referring on converting springs rates, which are actually lb per inch, and he is giving conversions to kg per mm
lb/in <-> kg/mm
Of course, if memory serves, the SI spring rate unit is actually N/m... make your own conversion factors with 1kg = 9.81N (in most places...
) and 1m = 1000mm
lb/in <-> kg/mm
) and 1m = 1000mm
