No V-TEC
Old Sep 27, 2004 | 09:09 AM
LeesB's Avatar
Default No V-TEC
I cant hit my vtec. oil is good changed solinoid and pressure switch
ls/vtec on boost and it loses all power past 6500 rpm i also checked every ground any ideas???
Old Sep 27, 2004 | 09:12 AM
eg6T's Avatar
Default Re: No V-TEC (LeesB)
do u have a vtec controller?what ecu?
Old Sep 27, 2004 | 09:15 AM
LeesB's Avatar
Default Re: No V-TEC (eg6T)
yes i do have a v-tec controller and its a chipped p-28 but i tried my stock one also and nothing
Old Sep 27, 2004 | 09:18 AM
eg6T's Avatar
what head are you running?what did you set your rpm at for vtc to pop?do u have stock cams?
Old Sep 27, 2004 | 09:20 AM
LeesB's Avatar
I have a itr head and cams its wierd it just started happening and i have had this motor for 6 mnths now
Old Sep 27, 2004 | 09:26 AM
eg6T's Avatar
when you have stock cams you are not suppose to mess with the vtec engagement.screwin with it will cause you to lose power and your car will run like crap,or vtec wont even hit.set the vtec contoller to the original rpm it is suppose to pop and see what happens.
Old Sep 27, 2004 | 09:27 AM
LeesB's Avatar
but now why would it work for 6 mnths and now nothing
Old Sep 27, 2004 | 09:29 AM
eg6T's Avatar
did you mess with the engagement?what rpm did u set it to engage?
Old Sep 27, 2004 | 09:31 AM
LeesB's Avatar
all motor i had it at 4800 but for the past six mnths its been at 6400
Old Sep 27, 2004 | 09:32 AM
eg6T's Avatar
just set it to stock engagement..i think 5500 rpm,see what happens.
Old Sep 27, 2004 | 09:34 AM
LeesB's Avatar
have tried it and nothing
i seriously have tried everything i can think of even totally disconected the v-afc and still notta
Old Sep 27, 2004 | 09:37 AM
eg6T's Avatar
the only thing i can think of is when you got a new selonoid..did you connect the wires correctly and did any wires fall out accidentally?
Old Sep 27, 2004 | 09:39 AM
LeesB's Avatar
only one wire on it and no codes i have no idea anymore now if i am correct v-tec is controlled by oil temp and speed correct???
Old Sep 27, 2004 | 09:41 AM
eg6T's Avatar
yea..speed sensor fucked up?
Old Sep 27, 2004 | 09:43 AM
LeesB's Avatar
still reads mph just fine and the controller says vtec is kickin in but its not
Old Sep 27, 2004 | 09:48 AM
eg6T's Avatar
my car was reading mph but vtec wasnt working,got a different speed sensor and it worked.im stumped if its not that,good luck
Old Sep 27, 2004 | 09:49 AM
eg6T's Avatar
there are 3 wires arent there...black,red,blue...
LeesB's Avatar
did you have a speed sensor code????
Old Sep 27, 2004 | 11:58 AM
eg6T's Avatar
i dont know,check engine lights been on since i got the swap due to the o2 sensor not connected
Old Sep 27, 2004 | 03:00 PM
Runnerdown's Avatar
Might want to check your oil pressure.
Old Sep 29, 2004 | 03:32 PM
LeesB's Avatar
OK how much oil pressure should my v-tec line have under say 5000 rpms
i am hooking a gauge straight to the feed line
Old Sep 29, 2004 | 03:58 PM
eg6T's Avatar
i dont know but at about 900rpm my b16 reads 25-28 psi
Old Sep 29, 2004 | 04:01 PM
LeesB's Avatar
and i changed sensors and that wasnt it either
nokaoi13
Jan 31, 2011 05:23 AM
LST2
Mar 10, 2008 08:54 AM
gavhowe
Sep 5, 2002 11:27 PM
mason
May 17, 2002 04:54 AM
arete213
Sep 10, 2001 08:44 AM
