What is a "poor mans type r" or what they call "mini type r"?
Old Sep 27, 2004 | 08:15 AM
DriveSlowHomie's Avatar
Default What is a "poor mans type r" or what they call "mini type r"?
Modified by cmGSR916 at 12:58 AM 12/13/2005
Old Sep 27, 2004 | 08:29 AM
lemongreenhatch's Avatar
Default Re: What is a "poor mans type r" or what they call "mini type r"? (cmGSR916)
gsr block si head
Old Sep 27, 2004 | 08:34 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: What is a "poor mans type r" or what they call "mini type r"? (poorman-type-r)
a 1.8 b series vtec block (gsr) and the b16 head (PR3). It's called a poor mans type r, because the ITR uses the same PR3 head, just with a mild hand port and polish and different valve train, and the block is a 1.8 vtec. I'm "kinda" doin a poor mans type r .. but it's a type r block with a b16 head
Old Sep 27, 2004 | 08:38 AM
JCushing's Avatar
i was also under the assumption that it would also involve R cams and either an R intake mani or clone....
Old Sep 27, 2004 | 10:27 AM
crxgsr91's Avatar
Default Re: What is a "poor mans type r" or what they call "mini type r"? (Odiedogcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx &raquo;</TD></TR><TR><TD CLASS="quote">a 1.8 b series vtec block (gsr) and the b16 head (PR3). It's called a poor mans type r, because the ITR uses the same PR3 head, just with a mild hand port and polish and different valve train, and the block is a 1.8 vtec. I'm "kinda" doin a poor mans type r .. but it's a type r block with a b16 head </TD></TR></TABLE>
Wouldent you have to include pistons of some sort as well. Putting an si head on a gsr block would lose compression and in turn hp.
Old Sep 27, 2004 | 10:40 AM
Default Re: What is a "poor mans type r" or what they call "mini type r"? (crxgsr91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldent you have to include pistons of some sort as well. Putting an si head on a gsr block would lose compression and in turn hp.</TD></TR></TABLE>
yes that is tru u would need to upgrade pistons
Old Sep 27, 2004 | 11:29 AM
DOHCtorTHRUST's Avatar
this would be pretty close to a "poor mans R" except, i have PR3 pistons
https://honda-tech.com/zerothread?id=1004094
Old Sep 27, 2004 | 11:54 AM
OLM-02R's Avatar
i think if u put a PR3 pistons on ur "poor mans R" your cr will be a lil higher than using itr pistons...
make sure to change ur pistons if ur doin "poor mans R" if not ur cr will be 9:8...
i got "poor mans R" xcept im using JDM P30 pistons...n better valve train
yes it has potential...
Old Sep 27, 2004 | 12:14 PM
Default Re: (OLM-02R)
thanx for the info...is this motor much better than a ls vtec setup?...alot of difference?
Old Sep 27, 2004 | 12:17 PM
Odiedogcx's Avatar
AIRBORNE
Default Re: (cmGSR916)
It's no different really. LSVTEC you're making a 1.8 non vtec block to a vtec block ... stroke and compression would be the only differences ... ls having a longer stroke i, than the gsr/itr i believe.
vtec-power
Nov 28, 2010 10:08 PM
heritage36
May 31, 2009 03:57 PM
TEGGRY
Dec 29, 2005 09:30 AM
bk92teg
Aug 20, 2004 08:32 PM
lemongreenhatch
Jun 2, 2004 02:42 PM
