Low on gas.....
Old Sep 27, 2004 | 06:05 AM
LouisianaCivic97's Avatar
Default Low on gas.....
When my 97 civic has a little less than 1/4 of a tank it turns over for a couple of seconds and then it starts......its been doin that ever since i had the car!!! WTF is wrong with it?!!?!?!
Old Sep 27, 2004 | 06:13 AM
deSigi's Avatar
Mine does the same thing. It's a common thing with civics and probably other cars too I'm sure. It's nothing to freak out about, it's happened to me plenty of times. Someone once explained to me why it does that, but I don't remember the explanation.
Does someone have the explanation for this?
Old Sep 27, 2004 | 06:31 AM
opkjoblacsh's Avatar
Default Re: (deSigi)
my car does the same thing but instad of sitting on a ¼ tank its like when im on E and its kina cold out side... but im sure its nothing to worrie about or put money into
Old Sep 27, 2004 | 06:41 AM
Targa250R's Avatar
be professional
Default Re: Low on gas..... (LouisianaCivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LouisianaCivic97 &raquo;</TD></TR><TR><TD CLASS="quote">When my 97 civic has a little less than 1/4 of a tank it turns over for a couple of seconds and then it starts......its been doin that ever since i had the car!!! WTF is wrong with it?!!?!?!</TD></TR></TABLE>
Nothing. Consider it a suggestion to fill up your damn fuel tank.
It's your fuel pump trying to pump fuel out of an empty tank. When you start it, turn it to the "on" position and allow it to prime the lines for a few seconds before engaging the starter. It should start immediately.
Old Sep 27, 2004 | 07:24 AM
mct121's Avatar
I also see that happen on my 2000 LX. I never made a big deal about it, but I did notice that if I park facing downhill it seems to do this less. ::shrugs::
Old Sep 27, 2004 | 07:26 AM
Jago's Avatar
Default Re: Low on gas..... (mct121)
its normal for all hondas to crank 4-8 times before startup
Old Sep 27, 2004 | 07:28 AM
Deemeetree's Avatar
Electrician
Default Re: Low on gas..... (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">its normal for all hondas to crank 4-8 times before startup
Speak for yourself. No more than 3 here. Usually 2 cranks, up it fires.
Old Sep 27, 2004 | 07:30 AM
CoxhEd's Avatar
Common problem.
dupes4lyfe
Nov 25, 2013 02:02 PM
boongley29
Acura TSX
25
Sep 19, 2007 01:52 PM
xonn
32
Dec 6, 2006 06:21 AM
JoeDaSoto
Nov 15, 2006 08:23 AM
M^Dawg
12
Aug 4, 2006 05:58 AM
