Buzzer disconect?
Old Sep 27, 2004 | 04:23 AM
STravisVrooman's Avatar
Default Buzzer disconect?
Hey guys, I just bought my Crx on saturday, and I have to slam the door several times to get the beeper to stop going off, I'm sure you guys have answered this question a hundred times but I didn't find anything from searching. Anyway I was just wondering where the beeper was located so I could unplug it, any help appreciated, thanks.
-Travis
Old Sep 27, 2004 | 05:32 AM
90civichbsi's Avatar
Default Re: Buzzer disconect? (STravisVrooman)
it is up in the seatbelt light, where the rear view mirror screws in, just unscrew thes 3 bolts and there is a plug behind it. unplug it and you wont have anymore beeping
Old Sep 27, 2004 | 05:44 AM
Speed PHreak's Avatar
Default Re: Buzzer disconect? (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">it is up in the seatbelt light, where the rear view mirror screws in, just unscrew thes 3 bolts and there is a plug behind it. unplug it and you wont have anymore beeping</TD></TR></TABLE>
He's talking about the door buzzer, which are the pin switches on the doors. You either need to replace the pins switches, go be ghetto and wrap some black electrical tape around the plastic "L" to fatten it up.
Old Sep 27, 2004 | 11:24 AM
Default Re: Buzzer disconect? (Speed PHreak)
I tried the tape thing and its still goes off, probably need a new switch, but is there anyway I can just disconnect the speaker? Or whatever it is.
-Travis
Old Sep 27, 2004 | 02:57 PM
CRXBart's Avatar
Is your domelight staying on also if so it is the door switch. In one case I had a friend who had one that would just keep buzing for no apparent reason. He tracked it to the fuse box, and then stabbed it with a screwdriver untill it quit beepeing.
Old Sep 27, 2004 | 04:26 PM
RedSI93's Avatar
I had that problem once, only it happened to me when i went went around a curve and weight shifted in the door, it was my 89 si...i tracked it to a wire on the seatbet thing inside the door.
Old Sep 27, 2004 | 04:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote">
He's talking about the door buzzer, which are the pin switches on the doors. You either need to replace the pins switches, go be ghetto and wrap some black electrical tape around the plastic "L" to fatten it up.</TD></TR></TABLE>
yes, but the beeping comes from that box, so if he didnt want to fix the problem and just stop the beeping, unpluging that would stop it
Old Sep 27, 2004 | 08:02 PM
yes, but the beeping comes from that box, so if he didnt want to fix the problem and just stop the beeping, unpluging that would stop it</TD></TR></TABLE>
Yea, unplugging that box will cure that beep. The civic's with seat belts on the doors have 2 sensors for the doors. The regular "L" shaped pin switch on the inside of the door jam, and they also have a switch thats built into the door latch on the inside of the door.
Old Sep 28, 2004 | 05:39 AM
My dome light would turn off, so I found it in the fuse panel and poped it off the curcuit board. Thanks for the replys.
-Travis
White_EG1
Feb 3, 2016 06:18 PM
S2KILLA
Honda S2000
Jun 23, 2007 09:41 AM
extracrunchie
Jun 7, 2007 12:04 PM
88crxhfb16
Sep 21, 2006 01:39 PM
Weston
Jul 18, 2003 12:28 AM
