1991 crx w/b18a
I have a code reading 13. It is the P.A. sensor. I have been getting a lot of problems with my idle also. How do I fix that sensor. The manual book says that the pa sensor is located in the ecu. My idle just keeps going up and down. I dont have any vaccum leaks. Can anybody help.
No I dont have any suggestions, but Im swapping a B18A into my 90 CRX, and would like to hear the solution to this problem for future reffernce.
Bump
Bump
there should be a sensor on the back side of the intake manifold that has "2" Coolant lines going into it and one "plug", that should be your problem with your idle if i can find a pic of one ill send it to you or post it. Let me know how it goes!!!
Modified by White90SiHatch at 8:10 PM 9/27/2004
Your car will kick hella *** once your done with your swap. I suggest you order an avid shift linkage. If you get an integra shift linkage your gonna have to cut and weld so that will be a bitch. That was the only pain in the *** for me. Oh and change your clutch. Your car will do 14's with all the basic mods. Have fun
mikester1222
Aug 19, 2009 01:14 PM
JDM EJ2
Jun 23, 2008 08:03 PM
waltlap
15
Aug 5, 2005 10:21 AM
