No v-tec engagement, and redline is at 6800
Old Sep 26, 2004 | 08:42 PM
Nyquil_Accord's Avatar
Default No v-tec engagement, and redline is at 6800
What's up everyone?
I just finished swapping a H22A into my 1995 Accord. The car runs perfectly fine, the car idles fine. The car runs like a champ, but theres a problem.
Problems:
1. When I decide to push it, rather Redlining at 7200 rpm, it only redlines at 6800 rpm.
2. Also, my v-tec doesn't engage. When Im climbing the rpm's, and when I get to 5500 ( v-tec engagement ), I don't feel the pull, or hear the v-tec.
My friend has the same swap, but his car redlines at 7200 rpm, and his v-tec engages at 5500.
I check the ECU, but it wasn't the ECU. I tried my buddy's ECU, and same results. No v-tec engagement, and Im still redline at 6800 rpm.
My buddy's ECU is a JUN Chipped P13 ECU. The ECU has a 9400 rpm rev limit. So, it can't be the ECU's.
3. Also, everytime I pull up my E-brake, my ABS light comes on.
Well, those are my problems with my swap, I don't know what to do. Could it be from the poor wiring, bad wires from the disturbtor, or my v-tec solenoid?
If threes anyone, who had the same problem, please help, or if anyone know what could be wrong. I appeciate the help. Thanks.
Old Sep 26, 2004 | 10:43 PM
SpeedingHatch's Avatar
Default Re: No v-tec engagement, and redline is at 6800 (Nyquil_Accord)
the engine needs to be warmed up, when its cold, vtec wont enage and will also cause premature redline.
If the engine is warmed and your not throwing any codes, i cant help ya
Old Sep 27, 2004 | 12:28 PM
PreludeSE's Avatar
I had this problem on my prelude before. V-tec won't kick in if there is a low level of engine oil in the tank. My engine is supposed to have 4.8L of oil but i ended up putting around 2.5L of oil to bring the level back to normal. That means 2.5L of oil was gone. Afterwards, I checked engine oil level once a week. So please check the engine oil level if it is below the min.
Old Sep 27, 2004 | 02:47 PM
Nick M's Avatar
Default Re: No v-tec engagement, and redline is at 6800 (PreludeSE)
triple check the harness was plugged in correctly, i had a code 22 when i did my swap, turned out i had some of the harness incorrectly plugged back in
Old Sep 28, 2004 | 09:36 PM
MikeLuder's Avatar
check your oil pressure switch and make sure it has the correct wiring, i had the wrong wire connected to my oil pressure switch and i had vtec but it redlined at 6800rpms. double check EVERYTHING!!
94ludeh22
Nov 16, 2005 07:14 AM
hman09
Feb 22, 2004 08:50 AM
chethewitt
Oct 23, 2002 06:02 PM
wiber1
Mar 24, 2002 04:21 PM
