h22 trans fluid leak
Old Sep 26, 2004 | 07:51 PM
foeverchillin's Avatar
Default h22 trans fluid leak
i just put in a new clutch and pressure plate in my h22 and when i put it all back together and i put about 300 miles on the clutch, but the trans fluid is leaking pretty bad and the clutch is slipping when i try to push it hard... i'm thinking new main seal and that means dropping the trans again... i tried thicker oil but it didnt work... any ideas
Old Sep 26, 2004 | 11:08 PM
mike3's Avatar
Did you break in your clutch or just bag it right away, and did you replace your axle seals? i didn't when i did my clutch, and they started leaking.
Old Sep 27, 2004 | 03:03 AM
AndyD's Avatar
Default Re: h22 trans fluid leak (foeverchillin)
Trans is leaking?? Slipping clutch and leaking trans fluid are not two issues that could be related....at least I can't think of anyway they are..
Are you sure that your axles went in all of the way into the trans?? Are you sure that the clutch was beld properly??
Old Sep 27, 2004 | 04:59 AM
Monkey Fing a Coconut's Avatar
Default Re: h22 trans fluid leak (AndyD)
now you know to always replace the cheapo seals whenever u replace anything that gives u access to them, when i changed out my clutch turns out the tranny main seal was leaking tranny fluid all over the clutch/fw in addition to my rear main seal leaking...
Old Sep 29, 2004 | 06:16 PM
so what parts do you think i should get... a new trans seal, main seal, axle seals, and maybe have the flywheel resurfaced... the flywheel didnt look like it had any heat spots, but i just want this thing to run perfect.... any other suggestions.. i want to make a parts list so i can order all this stuff... thanks for all your help
Old Sep 29, 2004 | 06:21 PM
Default Re: h22 trans fluid leak (twistedbydezign)
ok so what parts do you think i should order, i want to get a parts list together so i can order everything at honda bc they take like 5 years to get parts... new main seal, tranny seal, axle seals... im going to resurface the flywheel, it didnt look like it had any heat spots, but im not taking any chances anymore... i just want this thing to run right... any other suggestions? thanks for all the help..
Bradshaw
Jul 23, 2011 10:08 PM
kallmijonx2
48
May 2, 2010 08:36 PM
hondapwr
19
Dec 21, 2007 06:16 PM
eL
23
Sep 21, 2004 03:40 PM
toooslow
May 15, 2003 12:11 PM
