Am I just being paranoid? Blowby issue?
Old Sep 26, 2004 | 05:00 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Am I just being paranoid? Blowby issue?
Necessary background info:
97 civic EX, greddy kit, stock Y8, 128k miles, rebuilt head w/ARP's (1.5k miles), 2.5" test pipe/exhaust, DRAG III FMIC, blah blah.
I started it this morning (cold), and gave it a quick short rev (to about 3k) before putting it in reverse, and a LITTLE white smoke came out of the exhaust as I was backing out of the driveway.
Then it was gone? Only did it when the car was cold-started for a second then stops a second later and doesn't smoke at all when driving.
Was it just a bit of blowby since the motor's kinda old?
Also, I'm running a hose from my valve cover to my intake on my greddy pipe, just as they recommend. Would switching to a catchcan be a better way to run it? Am I getting oil on my turbo's blades?
EDIT: Forgot to add that I have opened the oil cap when idling, as well as the dipstick, and there's no smoke coming out.
Old Sep 26, 2004 | 05:25 PM
toolowsol's Avatar
Default Re: Am I just being paranoid? Blowby issue? (boostincoupe)
when the motor is cold, the pistons don't seal as well, I wouldn't worry about it, if it does it when the motor is up to opporating temp, then worry a little.
Old Sep 26, 2004 | 05:26 PM
Default Re: Am I just being paranoid? Blowby issue? (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">when the motor is cold, the pistons don't seal as well, I wouldn't worry about it, if it does it when the motor is up to opporating temp, then worry a little.</TD></TR></TABLE>
Okay, because like I said it only did it for a second on the initial cold-start.
Just checking.
Old Sep 26, 2004 | 05:43 PM
civicgsr209's Avatar
in the moring, there is condensaiton on the inside of your exaust piping. when you start your car for the first time in the morning, the heat from the exaust evaporates the water and it gets blown out through the muffler where it hits cool air again and turns to white "smoke". its nothing to worry about and has nothing to do with blow-by
Old Sep 26, 2004 | 05:58 PM
iiilgsrlll's Avatar
Your test pipe could also play a part in why you're seeing the smoke. There's a lot more stuff you'll see out of the tail pipe that you normally won't see with a cat.
Old Sep 26, 2004 | 06:29 PM
Bailhatch's Avatar
Default Re: Am I just being paranoid? Blowby issue? (civicgsr209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr209 &raquo;</TD></TR><TR><TD CLASS="quote">in the moring, there is condensaiton on the inside of your exaust piping. when you start your car for the first time in the morning, the heat from the exaust evaporates the water and it gets blown out through the muffler where it hits cool air again and turns to white "smoke". its nothing to worry about and has nothing to do with blow-by</TD></TR></TABLE>
true
Old Sep 27, 2004 | 05:06 AM
Default Re: Am I just being paranoid? Blowby issue? (Bailhatch)
Thanks guys
Old Sep 27, 2004 | 05:08 AM
Now for my next "I'm paranoid as hell" questions:
-My AIT sensor is hanging in my engine bay, meaning not in the charge or intake pipe. Is that affecting my performance? Are intake temps important with the greddy blue box?
-I am running a rubber hose from my valve cover to my greddy intake pipe, just as they recommend. Should I switch to a catch can? If so, what are the real benefits of it?
Old Sep 27, 2004 | 08:35 AM
bump for my dumbass questions
Old Sep 27, 2004 | 08:40 AM
m R g S r's Avatar
Why isn't it in the intake manifold like it should be?
Old Sep 27, 2004 | 08:55 AM
Default Re: Am I just being paranoid? Blowby issue? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Why isn't it in the intake manifold like it should be?</TD></TR></TABLE>
On SOHC's, they come from the factory lodged in the OEM intake pipe, which is now my Greddy charge pipe
Old Sep 27, 2004 | 01:36 PM
bump
Old Sep 27, 2004 | 01:44 PM
11psiTurboSI's Avatar
I drilled a hole and put it in the intake pipe with a rubber gourmet... took 5 mins to do... I think its for idle adjust when the intake temps change! I don't think it would hurt your performance I had mine out too back in the day.
Old Sep 27, 2004 | 01:54 PM
Default Re: Am I just being paranoid? Blowby issue? (9psiTurboSI)
Thanks
lotsohsmoke
Nov 10, 2010 07:48 PM
SIK IN DA HED
Jun 7, 2006 05:23 PM
danny98r
Oct 5, 2004 01:22 PM
TheJuggalo
Jul 27, 2002 08:27 AM
mracura
Jun 4, 2002 09:17 AM
