battery question
is there a company that can re-man. a dead(no good) battery? my battery is dead and will no longer take a charge. the problem is my car is rhd. so the poles are verry small. i don't want to buy a u.s. battery.
thanks.
this is type R related cause my battery is a small type r battery.
btw i actually orderd a battery from japan. but by the time it got here it was also dead. i guess from sitting arround too long.
thanks.
i read somewhere that the plates deteriorate, and needs to be replaced. i already tried to add more battery fluid. but i never tried draining it and replacing. maybe i'll do that tomorow.
i just figured, that there must be a company that re-build batteries, for those hard to replace ones like the one used on vintage and hotrods.
if not i guess will just get either a brail, or maybe a spoon since i'm somewhat a *****.
the lead plates will start to corode and which then clogs the pores in the plates, which then makes the plates useless. to be abel to do this you need to source new lead plates with the desired number of pores in the plates...which i think is just a waste of time and ultimatley a lost cause. you can try a VERY slow trickle charge and see...but that might be weeks??
adriv
Acura TL, RL & ZDX
Mar 28, 2014 10:21 PM
crxaddikt
Apr 5, 2009 01:45 PM
buzlink
16
Dec 13, 2002 12:25 AM
