Anyone running H23 block w/H22 crank & head?
Old Sep 26, 2004 | 11:29 AM
connvict's Avatar
Default Anyone running H23 block w/H22 crank & head?
I was curious if anyone was running this setup without any problems. I was considering this setup for a build for turbo so I dont have to find a JDM block.
Are there any issues with this swap? Would I have to buy pistons for H23 but rods & bearings for h22?
Thanks for any input.....
Mike
Old Sep 26, 2004 | 11:49 AM
flip1199's Avatar
Default Re: Anyone running H23 block w/H22 crank & head? (connvict)
h23 and h22 blocks are the same....
Old Sep 26, 2004 | 02:19 PM
satan_srv's Avatar
if you're running an H22 crank why wouldn't you just get an h22a shortblock?
Old Sep 26, 2004 | 02:41 PM
thehondaguru's Avatar
Default Re: Anyone running H23 block w/H22 crank & head? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">if you're running an H22 crank why wouldn't you just get an h22a shortblock?</TD></TR></TABLE>
Probebly because he doesnt want to buy a block and use his exsisting h23 block
Old Sep 26, 2004 | 06:08 PM
connvict's Avatar
Isn't it harder and more expensive to find an h22 shortblock? The reason i ask for all this is b/c i can get h23 blocks all day long.....
Old Sep 26, 2004 | 06:17 PM
connvict's Avatar
Also, companies like JE have different Part numbers for h22 & h23 pistons. I want to get 9:1.
BUt i need to know if I did the swap would i have to buy h23 pistons or can i use h22???
Old Sep 26, 2004 | 06:24 PM
AndyD's Avatar
Default Re: (connvict)
H23 and H22 blocks are EXACTLY the same. The ONLY difference is one reads, "H23" while the other reads, "H22".
With that said, you will not have to do any modifications.
Old Sep 26, 2004 | 06:39 PM
Default Re: (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">H23 and H22 blocks are EXACTLY the same. The ONLY difference is one reads, "H23" while the other reads, "H22".
With that said, you will not have to do any modifications. </TD></TR></TABLE>
yeah werd doggy
Old Sep 26, 2004 | 07:27 PM
flip1199's Avatar
Default Re: (95 lude)
get the h23 block, then just drop in a h22 crank, rods and pistons.
blkknight619
Aug 8, 2005 10:32 AM
my9thtry
Apr 25, 2005 10:12 AM
StraightCivic
Mar 16, 2005 06:05 PM
civicsitek GanGsTa
May 20, 2003 04:16 PM
Jordan_4WS
Jun 19, 2002 12:21 PM
