turbo integra sputtering and CEL 43 fuel supply, help please!
Ok we have a LS turbo that is ~9lbs of boost
440 rc injectors
safc
-50% 1-5
-42 5-7k
-25 8k
the car sputters at 1-3k and then hits a wall around 5.5k rpms
we threw a code 41 and 43 which is O2 sensor and fuel supply, i think its running too rich up top
what would cause this?
440 rc injectors
safc
-50% 1-5
-42 5-7k
-25 8k
no i dont think this is the hack.
there is a low pressure fmu inline
with the safc
and the 440 injectors
with the safc
i dont know why, this is my friends setup.
I use uberdata.
the fmu should not effect the stuttering at low rpms.
The only way I can explain it, is you rev it in neutral, and it hits a rev limit at 2k 2.5k and 3.5 k
if the gas is held steady it will rev, then drop, but if you give it more gas it will rev on by.
basically it bucks at low throttle input and then runs good from 3k to 5 or 6k then starts popping and backfiring.
the plugs are gapped to .30
I use uberdata.
if ur running the hack ditch the FMU, to much fuel...my friend hit a wall around 5k also, 550's and an FMU, ditched the FMU and set -40 across the board, even with -40 across the board and the initial running of the car before adjusting the fuel it ran ten times better. ditch the FMU and work it from there
I think I have the same problem it started happening after i put the test pipe on and put the o2 cen into the test pipe. How can i fix this problem? Ditch the test pipe and get a high flow cat and place the o2 cen back in the cat?
