96-98 civic dx motor in to 92eg civic, HELP PLEASE need INFO
im currently looking to a motor swap to buy asap and I came along two swap. one is from a 96 and the other one is from a 98. Im sure they are all the same, My question is will everything just bolt up and work?? OBD2 motor into OBD1 car. Can i use all the obd2 things???
Will I need: OBD1 distrubutor and injectors??? Down to the point, what will i need to change to make it work OR just let me know everything will work
Thanks in Advance guys.
u need a 92-95 DX disstributor, and the obd1 injectors off of your old engine
other than that everything should bolt in fine, only problem u might have is if its the y7, which the dx is. u will have that wierd intake manifold, and the IACV is 3 wires instead of 2, so u will need to change the intake manifold over to any 92-95 intake manifold, or i would buy a d16y8 manifold, and swap that in with the y7, much better flow than the obd1 manifold, and it will have the right connections u need for the swap, sense the y7 will not.
good luck with the project
thanks man.
One more thing, will my 92 harness plug straight up with no mods? So all i need to do is get obd1 distrubutor and injectors then ill be set, can any one else comfirm this. THank for the info
drzfamas718
13
May 30, 2011 05:22 PM
skate_volcom2006
10
Aug 28, 2008 12:53 PM
Unjockable
Oct 24, 2002 10:16 AM
