whats the difference between..
Old Sep 25, 2004 | 10:09 PM
Rare x3's Avatar
Default whats the difference between..
a Type R integ and a non Type R?
Old Sep 25, 2004 | 10:11 PM
Haleiwa-Brando's Avatar
Default Re: whats the difference between.. (Rare x3)
There are literally too many to list. There are over sixty different things in the engine alone. I suggest searching Google.
Old Sep 25, 2004 | 10:15 PM
rgbpmp's Avatar
Whats a type r?
No here is something.
http://www.superhonda.com/tech....html
Old Sep 25, 2004 | 10:54 PM
98itr0448's Avatar
One is an integra deprived of what it needs, similar to the starving kids in africa, and the other is a the Roy Jones Jr. of the import cars.
Old Sep 25, 2004 | 10:58 PM
rgbpmp's Avatar
Default Re: whats the difference between.. (98Itr-0448)
Could have said Oscar Delahoya of import cars, up until his last fight.
Damn!
Old Sep 25, 2004 | 11:02 PM
The Kernel's Avatar
Default Re: whats the difference between.. (rgbpmp)
http://itrca.com/FAQ/general/spottersguide.php
What sets the Type-R apart from any other Integra?
Engine/Drivetrain:
Revised high flow intake
Revised high flow exhaust
Polished and ported heads and ports
Molybdenum coated piston skirts
62mm throttle body
Lightweight valves
Lighter, stronger flywheel
Redline bumped up to 8400 RPM
Limited slip differential
Body/Chassis/Suspension:
Larger brakes (11.1 inch front, 10.2 inch rear)
Revised lighter ABS system
5 lug Hubs
15x6 Alloy wheels
Bridgestone RE-010 tires
New front air dam
Larger rear spoiler
Short throw transmission with shorter gears
Front shock tower bar
Two rear stabilizer bars
- There is really only one rear stabilizer bar.
The other bar, which was added for the ITR only,
is actually a lower suspension brace - it has no
dynamic suspension interaction other than to help
prevent chassis flex
Stiffened suspension
Little over a 1/2 inch (15mm) lower ride height
Faux Carbon Fiber instrument panel (Center Console in 2000/2001)
Deep bolstered, race-inspired seats
Subtraction of 147 lbs (No sunroof, A/C, sound deadening material)
Only offered in White until 2000 then Yellow and Black were also offered
No protective side moldings
Old Sep 26, 2004 | 12:52 AM
ITR 2K's Avatar
Default Re: whats the difference between.. (NBP #0933)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NBP #0933 &raquo;</TD></TR><TR><TD CLASS="quote">http://itrca.com/FAQ/general/spottersguide.php
Engine/Drivetrain:
62mm throttle body
Lightweight valves
5 lug Hubs
15x6 Alloy wheels
New front air dam
Larger rear spoiler
No protective side moldings</TD></TR></TABLE>
What he said.
Old Sep 26, 2004 | 09:04 AM
Misfit's Avatar
Engine/Drivetrain:
62mm throttle body
Lightweight valves
5 lug Hubs
15x6 Alloy wheels
New front air dam
Larger rear spoiler
you have too much time on your hands my friend.... a simple look at the fuggin FAQ would have been sufficient
Old Sep 26, 2004 | 11:20 AM
opiumdaze's Avatar
find a search button near you!
Old Sep 26, 2004 | 03:22 PM
itr_dc2's Avatar
Default Re: (opiumdaze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze &raquo;</TD></TR><TR><TD CLASS="quote">find a search button near you!</TD></TR></TABLE>
So wheres the closest search button outlet near 21047??
Old Sep 26, 2004 | 05:56 PM
opiumdaze's Avatar
Default Re: (itr_dc2)
hah beats me
Old Sep 27, 2004 | 03:14 PM
ITR 2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
So wheres the closest search button outlet near 21047?? </TD></TR></TABLE>
About 3 miles...
scp
Jun 5, 2017 01:47 PM
Choy
Jun 11, 2009 10:31 PM
enzozenuni
Dec 18, 2006 09:11 AM
HexLoco
Dec 7, 2005 09:03 PM
2camrex
Oct 7, 2005 05:11 AM
