where to find egt bung plug locally?
where are some good places to check locally before ordering online? i've checked home depot, lowes, and menards with no luck. i have searched the archives and i know that it is 1/8" npt 27 pitch thread, but i cant seem to find it locally. any advice? lemme know, thanks in advance.
Hope I didn't miss anything here, but 1/8 NPT 27 is a plain old 1/8 in pipe thread...
Or do you want something special like a stainless pipe plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose »</TD></TR><TR><TD CLASS="quote">Hope I didn't miss anything here, but 1/8 NPT 27 is a plain old 1/8 in pipe thread...
Or do you want something special like a stainless pipe plug?</TD></TR></TABLE>
i am having problems finding a plug also. i went to the plumbing section at home depot and there is nothing smaller than 1/4". the weird thing is that the 1/4" stuff looks too small to plug the egt bung.
Is that what you guys are after?
1/8 inch NPT (National Pipe Thread)
Tap drill 21/64 (0.328) with reamer
Tap drill Q (0.3320) with no tapered reamer post drill treatment
Nominal OD of the thread 0.405 keep in mind it is a tapered thread
Typical thread engagement 0.264 inch
If thats it, its plain ol 1/8 in NPT. Grainer and McMasterCarr has these fittings for sure. Locally a good plumbing or autoparts jobber should stock 1/8 in parts. Your right they are not "common"... Home depot probably starts stocking at 1/4 inch NPT, IIRC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose »</TD></TR><TR><TD CLASS="quote">Brass is fully liquid at 1750 oF, Bronze is fully liquid at 1850 oF. Dull red steel/cast iron is around 1250 oF.</TD></TR></TABLE>
sorry, but this doesnt sound right. cast iron becoming fully liquid at 1250*F. i have heard on people getting egt readings in this range and their manifolds werent melting.
anyone else know if a brass cap is a suitable egt plug? thanks in advance.
Re read it again, I think you might have missed my change of verbage. For the cast iron, I listed what would be a dull red heat temperataure, NOT the liquidus temp of cast iron...
I sort of snuck in the change to compare where melting the brass/bronze would be with the dull red we usually see on turbo housings...
