only 15psi of compression in cyl 3, help me out.
the other night my buddy was out racing around in his 98 gsr. only mods are intake and exhaust. he says he only hit rev limiter once (not a problem). and on the way home his car started running like sh*t. after doing a compression test, we found that 1,2,and 4 were all 240ish psi. cylinder 3 has only 15psi. is this most likely a bent/broken valve or a piston right or what? ive never heard of this happening to a honda. his car has less than 70k miles on it, im stumped. help me out
Sounds like he may have floated a valve, and it's not sealing all the way. Pull the head and check it out, it won't take you that long.
street dreams
Nov 21, 2004 04:48 PM
