94+ Integra Cluster in EF (SEARCHED)
I just put my 2001 Teg cluster into my 89 DX HB.....my question is that the highbeam/hazard lights are messed up.....when the ignition is off everything works fine.....however when I turn the ignition on....the hazard lights and the hibeam lights on the cluster alternate when flashing......aswell as the hazard lights stay lit up...even when turned off.....they are dim....but still lit up.......does anyone have any tips.....I figured bad ground....but I cant find any that are no good.
Any help is appreciated !
-Brad
-Brad
Check your wiring. Sounds like you did something wrong.
If followed some online wiring diagram then you might want to try tracing the wires yourself and see what went wrong.
kris9
Aug 23, 2012 04:11 AM
catsman50
15
Aug 1, 2011 11:57 AM
92 black bubble
10
Dec 13, 2008 10:01 AM
