How to: 70K Maintenance - sparkplugs, wires, rotor, cap, fuel filter
Old Sep 25, 2004 | 12:19 PM
mikestypeRR's Avatar
Default HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER.
Well the caR has 77k on it and is in desperate need of a tune up... I just purchased the caR acouple weeks back, and it need a face lift.... LEN hooked me up w/fast delivery and great service, all genuine honda parts.
This is what I did today, figure I would post the small project in case there are some people that would like to do this but, are weary and need some pics and help.
TIMMING BELT WILL BE INSTALLED AT LATER DATE
HERES A SHOT OF THE PARTS
THIS IS THE SIMPLE ONE JUST REMOVE THE WIRES,"MINE THAT LOOK LIKE HELL .
NEXT REMOVE OLD PLUGS AND INSTALL NEW ONES.... MAKE SURE YOU CHECK THE GAP..EVEN THOUGH IT SAYS PREGAPPED THERE NEVER RIGHT...ITS CALLS FOR .44 GAP ... WHEN I PULLED THEM FROM THE BOX THEY WERE .35
[B]NEXT TIGHTEN PLUGS TO 13FTLBS OF TOURQE,NOT 13 POUNDS OF WEED
B]
NEXT REMOVE THE CAP BY LOOSENING THE 3 LITTLE SCREWS "2 ON TOP.ONE ON BOTTOM" REOMOVE CAP... THERE WILL BE A LITTLE SCREW BEHIND THE ROTOR FACEING THE FIRE WALL REMOVE THIS... AND THE ROTOR WILL BE FREE TO REMOVE
NEXT REMOVE THE TOP BANJO BOLT ON THE FUEL FILTER THEN THE BOTTOM ONE, INSTALL NEW FILTER THEN TIGHTEN BOTLS " YOU MAY NEED TO DISMOUNT THE WHOLE FILTER ASSEMBLY FROM THE FIRE WALL SO THAT YOU CAN GET TO THE NUT TO REMOVE THE FILTER FROM THE CRADLE... I HAD TO DO THIS.
ok after I finished the install the car idled constantly at 700-900 rpms.. when before is was going from 1000 to 700 here and there... not very smooth... when i test drove the car I notice the throttle response was improved the car accelerated like butter.... and vtec engagment was less noticable,the car had more tourqe with more of a pull due to the butt dyno all in all it was a tune up well needed, its a very easy and basic tune up that really improves the cars performance back to were it needs to be... all you need is about 30 minutes to an hour.
another post will be added once timminng belt is installed.
hope this can be usefull.
Old Sep 25, 2004 | 12:23 PM
ONEcam's Avatar
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (mikestypeRR)
good write up gangsta foo, len's the man
Old Sep 25, 2004 | 12:43 PM
xbB's Avatar
xbB
Very nice writeup. I bet the car is super happy now
Old Sep 25, 2004 | 01:03 PM
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (CRXcellent)
yes, alot stronger... next it the timming belt,water pump, valve adjustment...then off to the dyno for a baseline run
Old Sep 25, 2004 | 01:16 PM
Tweakmeister's Avatar
I LOVE PICTARES
plugs are 14ft/lbs (well, used anyway).
Old Sep 25, 2004 | 01:17 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (Tweakmeister)
Nice pics foooo..when you gonna bring it down so I can see the new RRRRRRRR.
Old Sep 25, 2004 | 02:28 PM
SpeedMachine's Avatar
damn thanks for that gapping tip. i just installed my NGK Iridium IX spark plugs yesterday and i didnt bother to check the gap.
Old Sep 25, 2004 | 02:40 PM
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (SpeedMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedMachine &raquo;</TD></TR><TR><TD CLASS="quote">damn thanks for that gapping tip. i just installed my NGK Iridium IX spark plugs yesterday and i didnt bother to check the gap. </TD></TR></TABLE>
yeah no problem man, i never trust anything that says "pregapped" or "preset" or whatever it may be... always check....
.35-.44 is a big difference ... anyone know how the car would run with a smaller than stock gap... my guess is shitty .. but who knows, were are all the technical ITR owners when you need em
Old Sep 25, 2004 | 05:23 PM
ILUVTEC's Avatar
Mikey, atleast you aRe tRying, call D though....
LateR
Old Sep 25, 2004 | 05:54 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">
Finally someone that agree's with me. And took the time to show us.
Good mechanics rule: ALWAYS check the gap on your plugs regardless of if they are pregapped.
Nice writeup btw &
Old Sep 25, 2004 | 06:22 PM
LyL18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">the throttle response was improved the car accelerated like butter.... and vtec engagment was less noticable,the car had more tourqe with more of a pull due to the butt dyno </TD></TR></TABLE>
Whaaa?
Old Sep 25, 2004 | 06:29 PM
KOALA YUMMIES's Avatar
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (LyL18)
Your ground wire isnt attached how its supposed to be. Its supposed to be going to the valve cover bolts that go to the cylinder head FIY.
Old Sep 25, 2004 | 06:38 PM
migs's Avatar
Nice writeup. Get better quality pictures.
Old Sep 25, 2004 | 09:08 PM
dandc2's Avatar
Default Re: (migs)
good job mike now come over and help me with mine
Old Sep 25, 2004 | 09:58 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: (dandc2)
I'd check the distributor coils while you are at it. I had two go out within 90,000mi.
Old Sep 26, 2004 | 09:17 AM
Chubz's Avatar
Default Re: (ActiveAero)
good write up. I change out the fuel filter every 15,000 miles or once a year. I have to do my timing belt next. I did my valve adjustment just recently. I hear the crank pully bolt is a real abortion to get out. Anyone have any tips.
Old Sep 26, 2004 | 09:35 AM
Nishant's Avatar
Default Re: (Chubzilla)
nice write up
Old Sep 26, 2004 | 03:32 PM
machgo5go's Avatar
Default Re: (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">nice write up </TD></TR></TABLE>
I have only 24K miles in 4 1/2yrs since not daily driven.
From my previous 97R, a set of Managor 8.5mm wires has been
just sitting in a box. Do you think its worth installing it over OEM or
just waste of time?
Old Apr 21, 2005 | 03:12 PM
lDanny's Avatar
Default Re: (machgo5go)
any pictures that work?
Old Apr 21, 2005 | 03:17 PM
d.n.d.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lDanny &raquo;</TD></TR><TR><TD CLASS="quote">any pictures that work?</TD></TR></TABLE>
yea lol didnt work for me either but from written point nice stuff man
Old Apr 21, 2005 | 03:26 PM
808dc2's Avatar
good info
Old Apr 21, 2005 | 04:44 PM
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (808dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808dc2 &raquo;</TD></TR><TR><TD CLASS="quote">good info</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lDanny &raquo;</TD></TR><TR><TD CLASS="quote">any pictures that work?</TD></TR></TABLE>
THIS THREAD IS REALLY OLD .. I DELETED THE PICS OFF OF WE-TODD A LONG TIME AGO... HOPE THE WRITEN STUFF HELPS
Old Apr 21, 2005 | 07:09 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">THIS THREAD IS REALLY OLD .. I DELETED THE PICS OFF OF WE-TODD A LONG TIME AGO... HOPE THE WRITEN STUFF HELPS</TD></TR></TABLE>
Here's a few pictures that work, just for you Mike!
Old Apr 21, 2005 | 10:41 PM
penpen's Avatar
Default Re: HOW TO: ON 70K MAINTENICE ..PLUGS,WIRES,ROTOR,CAP,FUELFILTER. (Chris F)
? i don't quite understand-- ahem-- WHAT YOU MEAN?!
YOU USE PRINT SCRN BUTTON FOR TEH PICTURSZ NO?!!?!?11
Stevo F
Dec 29, 2013 02:47 PM
barkwaffle
Jun 2, 2005 10:09 AM
EF4lyfe
Sep 27, 2004 03:59 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
-=TWITCH=-
Feb 24, 2002 06:55 PM
