HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms
Old Sep 25, 2004 | 10:47 AM
EFin' Kyle's Avatar
Default HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms
ok my car runs fine and everything is smooth but it wont rev past 3000 rpms. it acts like the rev limiter is kicking in at 3000 rpms. what should i do? please help me soon i need this fixed by tomaro.
-Kyle
Old Sep 25, 2004 | 11:14 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms (crxstreetracer90)
check the timing belt
Old Sep 25, 2004 | 11:15 AM
EFin' Kyle's Avatar
Default Re: HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms (mar778c)
does that slip or what? i havtn takin it off. also somebody told me the dizzy? could that be it?
Old Sep 25, 2004 | 12:09 PM
90crxsib16's Avatar
Probably means you have multiple codes......I believe if you are running with any serious codes, it will do that to protect the engine.
Old Sep 25, 2004 | 12:15 PM
EFin' Kyle's Avatar
Default Re: HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms (90crxsib16)
so should i unplug the battery to reset the ecu or what?
Old Sep 25, 2004 | 03:14 PM
90crxsib16's Avatar
I would start with checking the codes!
Old Sep 25, 2004 | 03:20 PM
HatchBox's Avatar
Skoobie no more...
Old Sep 25, 2004 | 03:40 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxsib16 &raquo;</TD></TR><TR><TD CLASS="quote">I would start with checking the codes!</TD></TR></TABLE>
Old Sep 25, 2004 | 03:47 PM
EFin' Kyle's Avatar
Default Re: HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms (hondaguyef)
its the dizzy so if anyone had a obd0 dizzy for my b16 let me know. i need one ASAP
Old Oct 29, 2004 | 05:22 PM
krazie1's Avatar
BANNED
did u ever get the car started and the dizzy for ur car???
Old Oct 31, 2004 | 01:29 PM
thecowisbig's Avatar
Default Re: HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms (krazie1)
i have one for you if you still need it
Old Oct 31, 2004 | 03:06 PM
Bgladfelter's Avatar
My igniter caused that. Been through 3 remans already. Just but the whole distributor. The igniter is about 90 the dist is around 160-70.
Old Oct 31, 2004 | 06:57 PM
wompwomp61's Avatar
my input. its in limp mode. i think. i think limp wont rev past 3k.."limp home" mode.
Old Nov 1, 2004 | 09:12 AM
B SERIES US's Avatar
the problem is in to places 1 if u converted your car from tbi to mpfi it might be crank pos sensor in the dis. or the other place might be down in the ecu if the check engine light does not go out after the start up then the ecu might be bad,or it could be the connector on the ecu pin b10 b12 i think if u coverted your car to mpfi u had to swap two wires form c1 c2 and put them in b 10 b 12 so u might have them backwards or in the wrong pin place...or they might came out the conn
Old Nov 1, 2004 | 09:29 AM
mrspeaker's Avatar
Default Re: HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms (B SERIES US)
crank angle sensor in the dizzy doesnt let you rev past 3000rpm...
so check it out ..
accordbob
Nov 30, 2011 10:01 PM
SlowStockLude
10
Sep 8, 2005 09:12 AM
EFin' Kyle
Sep 28, 2004 06:33 AM
101 civic
Jun 13, 2004 09:04 PM
B18c1EKCpe
Mar 11, 2003 06:44 PM
