How to Remove the shock top hat?
Old Sep 25, 2004 | 07:21 AM
b18cEK's Avatar
Default How to Remove the shock top hat?
Alright, I am in the process of installing some omni-power coilovers on my ek hatch, and I got the entire spring/shock assembly out...
The problem is when I try to take the top hat off to get the spring out, the shaft and the nut just spin. I tried using a clamp, but this was no luck.
It is tockico illumina's with tein s-tech springs.
Also it would be fine to not use a spring compressor correct? Because I can push down on the tein springs and there isn't much tension.
Any help is appreciated! Thanks
Old Sep 25, 2004 | 07:55 AM
TallAssFilipino's Avatar
Default Re: How to Remove the shock top hat? (civic-rmod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-rmod &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I am in the process of installing some omni-power coilovers on my ek hatch, and I got the entire spring/shock assembly out...
Any help is appreciated! Thanks </TD></TR></TABLE>
Of the shock assembly, you're supposed to hold the shaft with an allen wrench and the nut with a box wrench and twist in opposite directions, accordingly. Anyway, just remove the top hat by the two nuts that you normally use when you add an upper strut tower bar. You'll have to anyway because as far as I've seen, doesn't the Omni-Power come with upper pillow mounts?
And no, you don't have to use a spring compressor if the springs aren't putting any force on the top hat once the whole shock assembly is out. Even if so, just aim the top hat portion towards a wall or curb outside your home.
Old Sep 25, 2004 | 08:06 AM
b18cEK's Avatar
Default Re: How to Remove the shock top hat? (TallAssFilipino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallAssFilipino &raquo;</TD></TR><TR><TD CLASS="quote">
Of the shock assembly, you're supposed to hold the shaft with an allen wrench and the nut with a box wrench and twist in opposite directions, accordingly. </TD></TR></TABLE>
See, that's what I don't understand... How do you hold the shaft with an allen wrench???
Old Sep 25, 2004 | 08:27 AM
Prod's Avatar
if you're saying that you're taking out tokico illuminas then you won't be able to put an allen wrench in the top of the shock shaft b/c the adjustment mechanism is there. On the threads nearest the top of the shock shaft on two sides the shaft should have no thread and be flat, you need to use a wrench to hold the shaft still and break the nut and you shouldn't need a spring compressor just don't take it apart in front of your face or anything.
Old Sep 25, 2004 | 08:33 AM
b18cEK's Avatar
Default Re: How to Remove the shock top hat? (Prod)
man, I dont know whats up with my tokico's cause I don't see the place on the shaft that you are talking about with no threads.......... am I supposed to pop off the adjustment mechanism?
Old Sep 25, 2004 | 10:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prod &raquo;</TD></TR><TR><TD CLASS="quote">if you're saying that you're taking out tokico illuminas then you won't be able to put an allen wrench in the top of the shock shaft b/c the adjustment mechanism is there. On the threads nearest the top of the shock shaft on two sides the shaft should have no thread and be flat, you need to use a wrench to hold the shaft still and break the nut and you shouldn't need a spring compressor just don't take it apart in front of your face or anything.</TD></TR></TABLE>
Ahhh... So, I take it the shafts on the Tokico Illumina's are different than the shafts on the Tokico blues?
If that's how the shafts on the Illumina's are, then I think it's a bad design because it's seems it's easier to strip while you're trying to hold them in place while releasing the nut.
Edit: I just took a look at some Illumina's. They're not all white and there are actually blue Illumina's too. Also, not all the shafts were designed the same way. Some of them don't have that non-threaded part just above the threaded portion, like you mentioned.
civic-rmod: Can you show is a picture of what your shafts look like or at least describe what it looks like? Help us help you.
Old Sep 25, 2004 | 10:22 AM
Heylookits shawn's Avatar
just use an impact gun and shoot it off, works like a charm.
Old Sep 25, 2004 | 11:06 AM
b18cEK's Avatar
Default Re: How to Remove the shock top hat? (Heylookits shawn)
Thanks for all the feedback.
Actually, the adjustment mechanism on top of the threaded shaft, just pops off and reveals where the allen key goes and your all set!
Old Sep 25, 2004 | 09:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-rmod &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the feedback.
Ahhh... so I had it right the first time.
Old Dec 10, 2012 | 08:00 PM
deorocompleto's Avatar
I kno this thread is old but I'm having problems can anyone make a diagram on how to remove this top hats I just
want to put my ebay coilovers but the strut spins I really don't get how the allen wrench works???
Old Dec 10, 2012 | 08:36 PM
98civdx's Avatar
Master Detailer
the allen wrench sits in the top of the piston to stop it from spinning.
Old Dec 11, 2012 | 02:42 AM
grumblemarc's Avatar
The Grumpiest
Get a pair of vise grips and lock them down tight on the shaft/piston. Simple. If you ever plan on reusing the old ones clamp at the very top of the piston near the top hat.
Old Dec 11, 2012 | 04:37 PM
Post Re: How to Remove the shock top hat?
I think I have an idea of what you are talking about thanks for the help
m1northreat
Suspension & Brakes
May 5, 2007 01:01 PM
hatch96y7
Sep 25, 2006 12:16 AM
lido
Suspension & Brakes
Nov 26, 2005 03:49 AM
fsck3r
14
Mar 25, 2005 04:40 PM
F.U.D.
Suspension & Brakes
10
Jan 13, 2005 01:16 PM
