Stiffer steering in the R
Old Sep 24, 2004 | 09:58 PM
JDM Factor's Avatar
Default Stiffer steering in the R
Do they make a shorter steering rack for the R? I don't want to take Power-steering out of the car, it is a street car but I'd like to have a little bit more of a go-kart feel, possibly stiffen it up a bit. Any suggestions?
Old Sep 24, 2004 | 10:04 PM
nightrider's Avatar
Default Re: Stiffer steering in the R (JDM Factor)
15X7 rims. that's all i have to say.
Old Sep 24, 2004 | 10:06 PM
Haleiwa-Brando's Avatar
I think the only way your going to get it it stiff is by dissabling the power steering and performing the required work to the rack it's self. That's the only 'go-kart' feel that I'm aware of. Perhaps the old timers have a better answer.
Bbasso's Avatar
Change out the stock mushy bushings for some stiff ones and make sure that the tires are properly filled (psi).
Old Sep 24, 2004 | 10:11 PM
JDM Factor's Avatar
I running 15x7 TE37's. When I switched over from the stock calipers to the spoon calipers, it was just ridiculous on how light the steering got. Have any of you guys noticed the same? Which kind of bushings should I get, where to get them?
Old Sep 24, 2004 | 10:13 PM
nightrider's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">I running 15x7 TE37's. </TD></TR></TABLE>
when i drove around for a couple weeks with my 15x7 kosei's, my car seemed like a go-kart to me.
Old Sep 24, 2004 | 10:14 PM
Bbasso's Avatar
I would search around and see what the reviews are for the bushings that are availible.
Some might be too hard...
Old Sep 24, 2004 | 10:18 PM
Muckman's Avatar
Moderator in Chief
There isnt a faster steering rack we can swap in. Believe me Ive looked hard. All G3 Integras have the same steering ratio and its not fast enough.
Old Sep 24, 2004 | 10:20 PM
Bbasso's Avatar
Default Re: Stiffer steering in the R (Muckman)
I think some sort of civic has a faster ratio rack that fits, but I'm not sure which one.
Old Sep 25, 2004 | 04:54 AM
.RJ's Avatar
.RJ
Default Re: Stiffer steering in the R (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">I think some sort of civic has a faster ratio rack that fits, but I'm not sure which one.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=993203
Old Sep 25, 2004 | 05:38 AM
i 4's Avatar
i 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">I running 15x7 TE37's. When I switched over from the stock calipers to the spoon calipers, it was just ridiculous on how light the steering got. Have any of you guys noticed the same? Which kind of bushings should I get, where to get them? </TD></TR></TABLE>
if you think it is too light, take the power steering belt off, get some tires with a stiff wall, check that the tire PSI is good, and see how you like it.
Old Sep 25, 2004 | 06:04 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Do they make a shorter steering rack for the R? I don't want to take Power-steering out of the car.... </TD></TR></TABLE>
If you want to keep power steering, then my advice would be to just leave things alone. You'd be opening up a can of worms, IMHO.
Although it can seem overassisted at times, it's really not all <u>that</u> bad, especially for a variable assist system the design of which is close to ten years old.
Under three turns lock to lock makes things pleasant on the track, IMHO.
If you are willing to do away with the power steering, then there are a couple of options available to you.
Old Sep 25, 2004 | 06:21 AM
.RJ's Avatar
.RJ
Default Re: Stiffer steering in the R (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">If you are willing to do away with the power steering, </TD></TR></TABLE>
Uhm hmm.....
Snizzoop
62
Jun 3, 2008 07:23 PM
nathanong87
Jul 7, 2006 06:48 AM
freakasis
13
Jul 21, 2005 09:52 AM
Speed_69
12
Apr 15, 2005 10:10 AM
turbotime
Oct 8, 2004 08:32 AM
