ITR brakes on 4-lug??
Old Dec 11, 2001 | 05:01 PM
Nighthawk GS-R's Avatar
New User
Default ITR brakes on 4-lug??
Can someone explain how to accolpish this and what has to be modified? i know some of you did this. know obviously i know ucant use the actuall 5 lug rotor..errrrr confused!!!
Old Dec 11, 2001 | 06:53 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: ITR brakes on 4-lug?? (Nighthawk GS-R)
www.fastbrakes.com
Old Dec 11, 2001 | 07:59 PM
owen_the_soyboy's Avatar
you CAN and must use the 5 lug rotor.
it must have a 4x100 hole pattern drilled into the hat.
you need a hub centric ring to space it centrally onto the hub. (5 lug teg rotors have a larger hub hole compared to 4 lug tegs).
you need to find/buy some accord wagon/prelude vtec/ITR calipers.
Mill off 3mm (or is it 5mm) from the side of the caliper bracket that touches the hub mounting surface.
Fastbrakes can get you a whole kit good to go for less time and money it would take you to do everything unless you are mechanically inclined, have a mill/machine shop handy, and have access to cheap calipers.
if you go 11" rotor, you may want to save up for Wilwood calipers. because the 5 lug calipers are fuggin HEAVY ! trust me!
Old Dec 11, 2001 | 09:02 PM
Rob Dizzle's Avatar
Default Re: ITR brakes on 4-lug?? (owen_the_soyboy)
https://honda-tech.com/zerothread?id=99130
https://honda-tech.com/zerothread?id=98353
Old Dec 16, 2001 | 05:53 PM
b17gsr's Avatar
I read somewhere on the net that the front rotors for a 90ish VW Corrado G60 is the same diameter as the ITR/Prelude SR-V but with the 4x100 bolt pattern. I'm not sure if the hub size, and ofset would be correct.
If so, the hole swap would be much cleaner and easier to do. Time to drop by the local autoparts store and start comparing the two.
Old Dec 17, 2001 | 06:39 AM
fastbrakes's Avatar
Default Re: (b17gsr)
The G60 rotor won't fit over the Teg hub, I tried to use it for an 11" kit early on. That's why I had to find another rotor....
rsangha13
Suspension & Brakes
Aug 21, 2014 02:59 PM
Triker
Apr 10, 2012 12:57 PM
Scotty Dosent Know
Suspension & Brakes
37
Aug 16, 2008 10:26 AM
JDMorgan
Aug 4, 2005 04:27 AM
10K4U
Mar 31, 2005 07:36 AM
