having a hard time shifting, any suggestions?
Old Sep 24, 2004 | 03:12 PM
TopNotchR's Avatar
Default having a hard time shifting, any suggestions?
I replaced the transmission fluid in the R, but still having a hard time shifting. The shifting feels "notchy". Any suggestions?
thx
Old Sep 24, 2004 | 03:30 PM
1GreyTeg's Avatar
Default Re: having a hard time shifting, any suggestions? (TopNotchR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopNotchR &raquo;</TD></TR><TR><TD CLASS="quote">I replaced the transmission fluid in the R, but still having a hard time shifting. The shifting feels "notchy". Any suggestions?
thx</TD></TR></TABLE>
Did you have any problems before you did the fluid change? A fluid change alone will not solve more serious issues.
What fluid did you use? Honda MTF hopefully?
How much did you refill it with?
Did it feel the slightest bit better right after the change?
Mine feels noticeably smoother after a flush/change. But I also don't have any tranny issues and I also change the fluid at least once a season and the car doesn't accrue more than 3k miles a year.
Old Sep 24, 2004 | 04:20 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopNotchR &raquo;</TD></TR><TR><TD CLASS="quote"> The shifting feels "notchy". Any suggestions?</TD></TR></TABLE>
Step 1 - Drain Honda MTF
Step 2 - Light Honda MTF on fire
Step 3 - Pour good fluid in
Old Sep 24, 2004 | 04:21 PM
1GreyTeg's Avatar
Default Re: having a hard time shifting, any suggestions? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Step 3 - Pour good fluid in</TD></TR></TABLE>
Ugh
Old Sep 24, 2004 | 04:35 PM
ITR184's Avatar
Try changing the brake fluid in the clutch master cylinder and bleed the system. Had some problems with this before. Usually that fluid gets black witch should be a sign of moisture getting in.
TopNotchR's Avatar
Default Re: having a hard time shifting, any suggestions? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
I had the problem before I changed the fluid. I used Honda MTF. I filled it according to Helms, adding "oil until it runs out..." ( p13-3 ). After the change...same. I have a really hard time getting into gear sometimes.
Do you think maybe it's the clutch?
thx
Old Sep 24, 2004 | 04:36 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Ugh </TD></TR></TABLE>
Old Sep 24, 2004 | 04:59 PM
1GreyTeg's Avatar
Ugh = again?
I was kinda guessing there was something else amiss.
Old Sep 24, 2004 | 05:04 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">I was kinda guessing there was something else amiss.
I wasnt. Maybe if your car is not driven much, or only street driven and not driven hard, the MTF is fine for you. It works fine in my accord. But i'm not going to pretend that my R has led a "only driven on sundays to church" life, and the MTF just feels like crap. I also need to replace the throwout and mainshaft bearings, and possibly a synchro sleeve set if that is any indication.
Old Sep 24, 2004 | 05:11 PM
1GreyTeg's Avatar
Amiss with his car not yours.
I have been through the MTF posts backwards and forwards and personally just figured if everything is doing fine by me then I really don't need anything else, at least not yet. I don't have any tranny issues thus far and I track far less than you so I don't find it neccessary to upgrade this fluid yet.
Old Sep 24, 2004 | 05:14 PM
.RJ's Avatar
.RJ
Yeah but you drive it only a few thousand miles a year.
When I was using the Honda MTF i was flushing after every weekend. I went 6 weekends (+ autox use) on my last change with Motul Gear300. I believe Willis was/is changing after every weekend also.
Old Sep 24, 2004 | 06:50 PM
vtec94civic's Avatar
could be your clutch or master cylinder. the same thing happened to me and the clutch was worn down to the rivets. also the pilot bearing was destroyed. i'm willing to bet its your clutch.
H22CD
Apr 21, 2006 08:16 AM
Jellybeans8
Jan 22, 2006 07:51 AM
Jon D
12
Jan 22, 2004 07:07 AM
Razor
Honda S2000
13
Sep 18, 2003 02:16 PM
ooooitswilson
18
Sep 15, 2003 02:09 PM
