70mm tb for a b16a2 too big or just fine???
Old Sep 24, 2004 | 02:43 PM
vtibrazil's Avatar
Default 70mm tb for a b16a2 too big or just fine???
i got a good deal on a 70mm throttle body and i was wondering if it would be a good idea for my b16a2 or if it wiould be too big thanks for the help....
Old Sep 24, 2004 | 03:49 PM
hotintegranights's Avatar
Default Re: 70mm tb for a b16a2 too big or just fine??? (vtibrazil)
def too big, the most i would recomend on a b16 is 64mm-65mm and thats if your making well over 180whp.
Old Sep 24, 2004 | 07:55 PM
92RED Hatch's Avatar
Default Re: 70mm tb for a b16a2 too big or just fine??? (hotintegranights)
I agree ..its just overkill if you use one that size....unless your motor is turbo or an n/a motor puttin down serious numbers then just don't mess with it......sell it and get one that better fits your motor and mods....good luck..
Old Sep 24, 2004 | 07:59 PM
Waachback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotintegranights &raquo;</TD></TR><TR><TD CLASS="quote">def too big, the most i would recomend on a b16 is 64mm-65mm and thats if your making well over 180whp. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotintegranights &raquo;</TD></TR><TR><TD CLASS="quote">def too big, the most i would recomend on a b16 is 64mm-65mm and thats if your making well over 180whp. </TD></TR></TABLE>
Old Sep 24, 2004 | 08:01 PM
OLM-02R's Avatar
yeah too big...
between 62-65mm would be ok...
wats ur setup by the way ??
Old Sep 24, 2004 | 08:04 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtibrazil &raquo;</TD></TR><TR><TD CLASS="quote">i got a good deal on a 70mm throttle body and i was wondering if it would be a good idea for my b16a2 or if it wiould be too big thanks for the help....</TD></TR></TABLE>
yes too big....are you going at 300whp right now?
with 70mm TB on b16 a2 with some bolt on i think you will lose power...too big =air's velocity as it approach to TB's inlet will decrease due to volumetric excessive by TB' diameter
type R has 62mm stock...and that is exceptable for 190hp on R's engine...bored out R's TB to 64, 65, 66 is ok...but you talking about b16a2 with 160 +some bolt on with 70mm...you must be crazy..
Blueprint
27
Jan 9, 2007 02:26 PM
CeeJayy
39
Nov 30, 2006 03:45 PM
civic-8442-
Jun 19, 2006 03:27 AM
brixity
12
Dec 26, 2004 04:11 PM
