Cam Gear(help!!!)
Old Sep 24, 2004 | 01:41 PM
Civichatch27's Avatar
Default Cam Gear(help!!!)
Does a d15 cam gear work with a 98 non vtec d16 head?
Im stuck right now and im not sure if i should continue!!!
Old Sep 24, 2004 | 01:43 PM
dr_latino999's Avatar
Default Re: Cam Gear(help!!!) (Civichatch27)
Nope, aparently the 96-00 are different, even though most cam gears say "88-00"
Old Sep 24, 2004 | 01:44 PM
Default Re: Cam Gear(help!!!) (dr_latino999)
That was fast, thanks!
What would happen if i try it? Timing would be off?
Old Sep 24, 2004 | 01:53 PM
Yup, I can't remember how much by though.
Old Sep 24, 2004 | 01:55 PM
is there any way to make it work, i need my car to go to the junk yard
Old Sep 24, 2004 | 02:00 PM
Ya, just use a timing light to get everything set up right. I MAY BE WRONG since I have never tried it myself so you may be able to adjust it up. Which junkyard are you going to by the way?
Old Sep 24, 2004 | 02:01 PM
J&B in Bithlo.
Old Sep 24, 2004 | 02:04 PM
I lined up all the marks, and im TDC, but im guessing that really doesnt matter with the cam gear im using, Do you think im probably off by a couple of teeth?
bigsnorlax
Apr 20, 2009 09:18 AM
g1itchgsr
Mar 6, 2008 03:03 PM
mrnice1058
Nov 8, 2004 03:34 AM
d15maverick
May 3, 2004 09:14 PM
Black96Cobra
Oct 28, 2001 11:06 PM
