Power window wont roll up, help please!
Old Sep 24, 2004 | 01:08 PM
4bangin's Avatar
Default Power window wont roll up, help please!
I have a 93 prelude si. I never had any problems with the windows, they never seemed like they were about to die or anything. One day the passanger side window switch wouldnt roll the window down. I tried the driver switch and it worked fine. Pass. window rolled down. Now, it wont roll back up with either switch. Anyone have an idea what the problem might be? Driver window still works fine. tia
Old Sep 25, 2004 | 08:21 AM
4bangin's Avatar
Default Re: Power window wont roll up, help please! (4bangin)
Old Sep 25, 2004 | 08:24 AM
92hondalude's Avatar
the motor to the window maybe or it might the the connector at the bottom of the switch, put the switch out of your door and see if the connection is good. If it is good then it may be a fuse.
Old Sep 25, 2004 | 08:29 AM
britishlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bangin &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 prelude si. I never had any problems with the windows, they never seemed like they were about to die or anything. One day the passanger side window switch wouldnt roll the window down. I tried the driver switch and it worked fine. Pass. window rolled down. Now, it wont roll back up with either switch. Anyone have an idea what the problem might be? Driver window still works fine. tia</TD></TR></TABLE>
All I can think of is check the fuses are ok then see if there's power at the motor when you operate the switch, if you find power at the motor and it still dosn't work then you probably need a new motor, again check all connections to switch and motor make sure power is at the switch as well. I have posted a link of a diagram of a 93 si power window it may help you if you need to get at things.
http://www.hondaautomotivepart...INDOW
Old Sep 25, 2004 | 08:31 AM
darkd1gt's Avatar
mine does that too my car has a different door on it bc it was wrecked and it like speeds up like it has boost on it half way up but it has a lot of lag untill then lol
Old Sep 25, 2004 | 08:37 AM
Default Re: Power window wont roll up, help please! (mattspivey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattspivey &raquo;</TD></TR><TR><TD CLASS="quote">mine does that too my car has a different door on it bc it was wrecked and it like speeds up like it has boost on it half way up but it has a lot of lag untill then lol </TD></TR></TABLE>
Sounds like yours is just needing the runners cleaning out and re-apply some new light grease on them, also a light spray of silicone around the rubber seals helps cut down on friction when the window enters the seals and keeps the window sliding smoothly with less resistance.
Old Sep 25, 2004 | 11:40 AM
Exryder300's Avatar
I have a 93 too and i have problems with my passenger side window as well. the passenger switch picks and choses when it wants to work and when it doesnt want to, really odd
Old Sep 25, 2004 | 01:11 PM
Default Re: Power window wont roll up, help please! (Exryder300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exryder300 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 too and i have problems with my passenger side window as well. the passenger switch picks and choses when it wants to work and when it doesnt want to, really odd</TD></TR></TABLE>
Two probable causes on that are loose or bad connection in the circuit, or a bad switch with contacts worn or bad. Check all the connections for firmness and make sure wiring is in good condition from motor to switch up to fusebox, if not found check the switch itself try giving it a good spray inside with some electrical contact cleaner, if that fails a new switch is the next step.
Old Oct 3, 2004 | 02:05 PM
iCe_2x's Avatar
Default Re: Power window wont roll up, help please! (britishlude)
I just had this happen on my 95 si... my pass. window won't do a thing, motor has power tho
Old Oct 3, 2004 | 02:23 PM
Default Re: Power window wont roll up, help please! (iCe_2x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iCe_2x &raquo;</TD></TR><TR><TD CLASS="quote">I just had this happen on my 95 si... my pass. window won't do a thing, motor has power tho</TD></TR></TABLE>
First check all connections are good, if you have power at the window motor when the switch is operated it seems like your motor is burnt out or jammed, try giving it a sharp tap to jar it into action, if it's jammed it may just free it, failing that then sorry but it's a new motor needed.
Old Oct 3, 2004 | 10:16 PM
iCe_2x's Avatar
how much is a new motor?
Old Oct 3, 2004 | 11:27 PM
ph8ed4life's Avatar
I've taken my switch apart for the same prob, and here';s what I found:
the contacts that are cast into the plastic melt into it, causeing a loss of connection by the swinging arm-like piece that moves and completes the circut when you move the switch. You can bend the arm piece(you'll see what I'm talking about if you take it apart) but it could stop working again...my pass. side was fixed, then stopped again and will only work if you wiggle and jiggle it just correctly. BUT, be careful if you take it apart there are springs and small stuff to lose...good luck!!
Old Oct 4, 2004 | 03:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iCe_2x &raquo;</TD></TR><TR><TD CLASS="quote">how much is a new motor?</TD></TR></TABLE>
Whew ! Expensive $202 from Majestic : This is one of those parts that really is worth getting from a breakers.
spd18
Nov 9, 2003 01:57 PM
TheIntegraGuy
May 15, 2003 06:18 AM
