jdm front, HID problem
Old Sep 24, 2004 | 11:03 AM
b16hybridsol's Avatar
Default jdm front, HID problem
finally got my front all welded up, wired the headlights up last night except for the fog lights (still trying to figureout how i want to do them), anyways i wired up the drivers side, turned it on, no problem. Then i wire up the passenger side, turn it on and the HID was flashing like a strobe light. I put a test light on the HID wire at the plug and its dimmer on the passenger side than on the drivers side. Do i need to run a relay for the HIDs themselves so they get straight battery voltage? The stock wire for the low beams (where the HIDs hook up) is pretty tiny). Or are they supposed to work perfectly fine off the stock wires?
Old Sep 24, 2004 | 11:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: jdm front, HID problem (b16hybridsol)
HID ballasts require alot of current on initial startup, did you replace your headlight fuses for 20W fuses to handle that extra current draw right when you first turn them on?
Old Sep 24, 2004 | 12:43 PM
LSvtec03's Avatar
Default Re: jdm front, HID problem (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">HID ballasts require alot of current on initial startup, did you replace your headlight fuses for 20W fuses to handle that extra current draw right when you first turn them on?</TD></TR></TABLE>
yup, try that. i had the same problem and didnt realize that i needed to do that at first
Old Sep 24, 2004 | 06:59 PM
migs's Avatar
It worked fine on my stock wires the first go around. Just needed a good ground to fix that flicker.
Old Sep 24, 2004 | 08:00 PM
xTurtle714x's Avatar
Default Re: (migs)
maybe a relay harness will work...check HIDPLanet.com they have a forum where alot of peopel are helpful
Old Sep 25, 2004 | 01:45 AM
Default Re: (xTurtle714x)
tried 20 and 30a fuses, and it still didn;t work. All connections are solid, i'm goign to check grounds again tomorrow
_EF9
Lighting
Nov 25, 2012 05:58 PM
choua01
Aug 8, 2010 10:51 PM
simriv123
Jul 16, 2007 07:51 PM
mugen4dr95
May 31, 2004 03:42 PM
mrmigos
Jan 29, 2003 03:55 PM
