Gray CRX seat question.
I have a 91 crx and due to ware and tear I have had to replace the seats. I recently had someone back home pick up what I was told were CRX SI seats but when I got home to take a look at them they had gray strips down the middle, and no rear pocket in the passenger side. I didn't mind but when I went to put them in, they didn't line up. What year are the gray seats from, and why aren't they fitting? Is this a user error, or did I get screwed? Thanks.
Could be 86-89 Integra seats.
Do you honestly not know what seats they are?
I mean can you not tell by the shape.
I can look at just about any Civic seat and know where it came from (USDM)
no they have the exact same shape as the CRX seat, i honestly think they are crx seats, i was just thinking they may have been 90 crx seats rather than 91, but even still i thought that 90-91 seats fit with no problems?
well, are they two tone? What do you mean by gray stripes? horizontal or vertical?
90/91 seats are the same. Maybe they just have different rails on them?
Swap your stock rails and see what happens.
are they civic si seats they look almost the same (slightly diff color pattern) have the same shape as the crx but wont just bolt inthe crx i think the rails are nerrower on the civic sets (i think may be the other way arond) then the crx seat
Sounds like DX seats, if the headrests have a hole in them, they might be SI's, solid headrest = DX seats, and i think the bolts are different between certain years and trim, like maybe theyre 88 DX's or HF's or somethin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexerin »</TD></TR><TR><TD CLASS="quote">sounds like 88-89 USDM CRX Si seats to me... they have different rails, just swap the 90/91 rails over. i have a set that is set up like that and its fine.</TD></TR></TABLE>
yeah, with a little research i've found out that they are 88-89, so will they work if i swap the rails...can i swap the rails?
i got my 88-89 seats with the 90-91 rails already on them, so i'm not sure if the whole pan was swapped or just the rails, but it is possible to make them fit in a 90-91 with one of those two methods.
