What do I need to do to my stock gsr throttle body to work on skunk2 mani?
What do I need to do to my stock gsr throttle body to work on skunk2 mani? I have the type r throttle cable bracket and im still using my stock civic throttle cable. (this is in my eg btw)
b18c in my eg...
b18c in my eg...
you need to change the throttle cable pulley. the Type r one pulls the opposite way.
They don't sell this part separately at the dealer, so you need to find one off a Non GSR or Civic.
And you may need to buy the type R throttle cable cause you may need the correct tension and slack to get it right.
You know, the Skunk2 install has more suprises than you think.
This is the extras I needed to buy to make everything perfect:
Skunk2 Manifold (obviously)
GSR IM gasket
Type R TB (or stock GSR one with Non GSR pulley)
GSR or Type r TB Gasket (depends on which one used)
Type R throttle Cable Bracket
Type R Air Intake Arm (or aftermarket made for type R
Type R or LS fuel Pipe (GSR one is a real tight squeeze, can use, but sketchy)
Type R fuel rail stay bracket (GSR one is too short, not needed, but good for support)
I'll take pictures of my setup later. I am waiting for the Type R fuel pipe on order from Acura, the stock one fits, but is a really tight fit. I rather spend the money and get the right one then have it break on me and spill gasoline all over my engine.
Some Misc hoses and extra little stuff
any other questions, just ask
GSR IM gasket
I like to use the B16 throttle body pulleys b/c they're the same size as the ITR throttle pulleys.
I can either sell you just the pulley and return spring or I can pre-assemble an OBD-1 GS-R throttle body w/ the B16 pulley/spring for you.
during my install..this is exactly what i looked for and bought:
brand new itr throttle cable
new itr throttle cable bracket
new GSR intake manifold gasket (hondata)
non gsr throttle body pulley (i got it used in the classifieds off of a dx)
gsr throttle body gasket
ITR CAI (or you can use b16 or LS intake)
and while your at it, you could replace the fuel filter with a new one
And as for buying a new fuel pipe line or whatever.....i justed my gsr one but bent it to fit right......works and fits perfectly fine. Just dont bend it so much that you cause a kink in the line.
here is how my skunk 2 im setup look liked,hondata im gasket,itr tb,cable,bracket,itr fuel line,comptech itr icebox/itr intake
or to save money ,you can use ls pulley spring
The only parts i bought for my 94 gsr was new IM gasket and TB gasket.
If u dont like the way throttle cable is routed then u can get the non gsr throttle pulley and R cable and bracket.
i just replaced the gaskets also. i lived with the throttle cable sticking in the air. i know someone that has been for 3 years with it like that and no problems. it comes down to how clean you want it to look
did you advanced ur timing distributor...it looks like you did something to it...lol...dont blow it
if i install that Skink IM do i need to change any ECU setup? or anything? or its just bolt on like intake? install and done?
And will J's racing intake will fit? no problem with AC line or ABS line?
its recommended that you get a program because you no longer have the secondary runners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee »</TD></TR><TR><TD CLASS="quote">its recommended that you get a program because you no longer have the secondary runners. </TD></TR></TABLE>
which is better without secondaries runners right?
i have a p28 ecu this will work for my new skunk2 im?
how u tuned? what do u need to tuned?
please elaborate, a chip? new ecu? tuning?, just curious
FuNkDrSpOt
Nov 18, 2005 01:50 AM
fred92htch
Apr 7, 2003 07:55 PM
GruvyTune
Aug 6, 2001 07:32 PM
GruvyTune
Jul 24, 2001 07:39 AM
