Calling all Techs: 95 Gsr into a 95 LS
Old Dec 11, 2001 | 01:28 PM
BeanRacer's Avatar
New User
Default Calling all Techs: 95 Gsr into a 95 LS
I finished the swap and the car is not running with fully potential. I ran the knock sensor, the vtec ground, and some other wires but I'm not sure if I did it correctly. I keep getting the Vtec Soleniod engine code. Which wire is it and where exactly can i find? Is it on the driver side or passenger side harness? Please help. Any other advice.
Old Dec 11, 2001 | 04:34 PM
APEX i GSR's Avatar
Default Re: Calling all Techs: 95 Gsr into a 95 LS (BeanRacer)
check the wire coming from the Vtec solenoid on the side of the head.
Old Dec 11, 2001 | 07:12 PM
B_CRUZ!'s Avatar
you said you put the gs-r motor in the LS. You should know where the wire is cause didn't you have to add it in your self? just follow the wires from the solenoid.
Old Dec 11, 2001 | 07:58 PM
milo's Avatar
sup bean!!! your VTEC SOLENOID WIRE is ON THE PASSENGER'S SIDE.. and it goes to A4 ON THE ECU...you have the option of directly tapping into that wire where ur vtec solenoid is (u know where it is, right?) to the ecu or follow that wire to the engine harness and wire it to the ecu...hope it helps.. goodluck!!!
http://www.civicb18c1.freewebspace.com/index.html
[Modified by milo, 5:11 AM 12/12/2001]
Old Dec 11, 2001 | 08:18 PM
BeanRacer's Avatar
New User
Default Re: Calling all Techs: 95 Gsr into a 95 LS (milo)
Milo, Which would you suggest? Tap the solenoid wire to A4 or Tapping into the harness to A4?
Old Dec 11, 2001 | 08:19 PM
BeanRacer's Avatar
New User
Milo, Which would you suggest? Tap the solenoid wire to A4 or Tapping into the harness to A4? What about the IAB wires? Where are these? What color are they?
Old Dec 11, 2001 | 08:33 PM
milo's Avatar
FOR A CLEAN SET UP, TAP INTO THE HARNESS TO THE ECU..
OKAY FOR IAB--ITS THE PINK/BLUE WIRE.
Old Dec 11, 2001 | 08:35 PM
BeanRacer's Avatar
New User
What side is that pink/blue wire? driver side or passenger side harness and where do you plub them in the ecu?
Old Dec 11, 2001 | 08:47 PM
milo's Avatar
DRIVER'S I THINK..JUST LOOK THROUGH THE WIRES BOTH SIDES..U CANT MISS IT..I THINK IT GOES TO A17 (TRY IT, IM NOT SURE)...
DID THE VTEC SOL WIRING GET RID OF THE WARNING LIGHT??
civic_boy23
Feb 2, 2007 07:15 PM
VTECisSeXY
41
Jan 15, 2006 06:19 PM
lilbluehatch
12
Apr 16, 2005 05:43 PM
myDC4rox
Jan 9, 2005 06:54 AM
Soy Bean
Jun 14, 2004 04:27 PM
