my head valve bolts seem lose
dann today i pop up the hood...and just curious about how tight the bolts of my head valve cover are...god dann...they are so lose...are they suppose to be like that...lose bolts = leak right...im scare...anyone have any suggestion
well i turn the bolt little bit not even that much of a force i putted in...then it just suprised me that they are so lose...
any suggestion...what should i do? is it normal...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr »</TD></TR><TR><TD CLASS="quote">dann today i pop up the hood...and just curious about how tight the bolts of my head valve cover are...god dann...they are so lose...are they suppose to be like that...lose bolts = leak right...im scare...anyone have any suggestion
any suggestion...what should i do? is it normal...</TD></TR></TABLE>
oh well i can't even tight them they keep turning...are they broke or something anyone know?
It sounds like they are stripped, you might need new nuts or bolts. The torque spec on the VC bolts are only 7 ft/lbs, so if they were overtightened it is very possible to strip or break them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr »</TD></TR><TR><TD CLASS="quote">It sounds like they are stripped, you might need new nuts or bolts. The torque spec on the VC bolts are only 7 ft/lbs, so if they were overtightened it is very possible to strip or break them.</TD></TR></TABLE>
oh dann only 7ft/lbs? oh god...shesh im dead...gotta go to dealer...i guess....thanx...
VXpride
Jul 31, 2003 08:53 AM
