ep3 pulleys
it's a waste. we don't have a power steering pump/pulley, so you wouldn't need that one. The only other ones are the ac and alt. But to me that's a waste imo...nothing to be gained worth while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal »</TD></TR><TR><TD CLASS="quote">what about the crank?
doesn't unorthodox have a set for the EP3?</TD></TR></TABLE>
oh yes, I thought you were wanting info on the other ones. I know a few have done that......go for it I guess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02SilverSiHB »</TD></TR><TR><TD CLASS="quote">it's a waste. we don't have a power steering pump/pulley, so you wouldn't need that one. The only other ones are the ac and alt. But to me that's a waste imo...nothing to be gained worth while.</TD></TR></TABLE>
You have HP numbers to back this up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
You have HP numbers to back this up?</TD></TR></TABLE>
no, do you have any to back it up that it is worth it?
no, do you have any to back it up that it is worth it?</TD></TR></TABLE>
I never said it was or wasn't worth it. You were the one making the claims, not I.
If we want to keep this a tech forum, generalizations do no one any good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabends »</TD></TR><TR><TD CLASS="quote">so no one has any info for me...just bickering?</TD></TR></TABLE>
I've heard mixed things about pulleys. some people say don't change them because there is a harmonic balancer in them. and some people swear it works. so I'm as confused as you are.
they do improve your low end response a bit. But like aznbo1626 stated, many do not get these because the crank pulley on stock Honda engines have a harmonic balancer (rubber o-ring) to help with the crank vibrations. Spun rod bearings would result. However, no confirmed cases of this was tied with the usage of the UR pulley.
Do a search.
Do a search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabends »</TD></TR><TR><TD CLASS="quote">thanks for the info.....and not bickering</TD></TR></TABLE>
No one was bickering. Would you prefer I let misinformation or unsupported facts float around in these threads?
It was to help you and others reading, not crash the thread.
one honda engines are internally balance k series i would assume would also be internally balanced like previous honda engines.... if u were to get a crank pulley and put it on from the box this would be bad....u need to have it balanced first by a machine shop this is a must and will save u from having trouble in the future....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMB16Ahatch »</TD></TR><TR><TD CLASS="quote">one honda engines are internally balance k series i would assume would also be internally balanced like previous honda engines.... if u were to get a crank pulley and put it on from the box this would be bad....u need to have it balanced first by a machine shop this is a must and will save u from having trouble in the future....</TD></TR></TABLE>
yeah, I was going to state that also, but I don't want to bicker hahaha
here's my tech info...don't waste your damn money on some stupid mod. that's why there is no tech info on this...next
TeamTooQuick
Aug 21, 2003 06:54 PM
