putting a B16 head on a LS B18 block
Old Sep 23, 2004 | 08:44 AM
SouthPinesPunk's Avatar
Default putting a B16 head on a LS B18 block
I want to make my 93 LS a v-tec car and im getting the head, intake manifold, header, ecu but im not sure if theres anything else i need.
Old Sep 23, 2004 | 09:23 AM
Sack Master's Avatar
Default Re: putting a B16 head on a LS B18 block (SouthPinesPunk)
Water pump, timing belt, oil pump, oil lines, distributor, head gasket, etc etc.
Old Sep 23, 2004 | 02:59 PM
Default Re: putting a B16 head on a LS B18 block (Sack Master)
so i should be good to go if I get a B16 longblock?
Old Sep 23, 2004 | 03:33 PM
purplegsr's Avatar
http://www.g2ic.com/tegtips/engine/15.html
check out the engine swap guide on g2ic.com, it should answer some of your questions. If you are going to do lsvtec, then search here for 'lsvtec'. You should be able to find as much info as necessary from those 2 sources.
Modified by purplegsr at 12:44 AM 9/24/2004
Old Sep 23, 2004 | 03:50 PM
smart monkey's Avatar
don't forget the dist. I mean you can mod the ls one but it is not perfect.
Old Sep 28, 2004 | 08:57 AM
well now a friend of mine is selling me his GSR head intake manifold and vtec solinoid and my block is built with type-R pistons and will be able to turn 9-10 grand no problem so with a dist head gasket and ecu i should be set
Old Sep 28, 2004 | 09:04 AM
G-bonic's Avatar
Hijacked
LS-VTEC search search search... this topic has been around here so many times.....
Old Sep 28, 2004 | 09:15 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SouthPinesPunk &raquo;</TD></TR><TR><TD CLASS="quote">well now a friend of mine is selling me his GSR head intake manifold and vtec solinoid and my block is built with type-R pistons and will be able to turn 9-10 grand no problem so with a dist head gasket and ecu i should be set</TD></TR></TABLE>
haha.
I bet your motor doesn't last more than 5,000 miles before you spin a rod bearing at the very least. Any takers?
Old Sep 28, 2004 | 09:17 AM
Phatch99's Avatar
try the search button i'm sure there's plenty of info on this kinda set-up.
Old Sep 28, 2004 | 09:27 AM
Default Re: putting a B16 head on a LS B18 block (arw321)
well its already been 16,000 and no problem so i think im good
Old Sep 28, 2004 | 10:01 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SouthPinesPunk &raquo;</TD></TR><TR><TD CLASS="quote">well its already been 16,000 and no problem so i think im good</TD></TR></TABLE>
Elaborate on your "built block", if you will. 16,000 miles of 9 or 10,000 RPM shifts isn't something many LS blocks can handle, built or not.
It's just a matter of time until something lets go.
No offense, but it doesn't sound like you've researched this much, and a person with limited knowledge attempting to build an ls/vtec is a recipe for disaster.
Good luck.
Old Sep 28, 2004 | 10:09 AM
patmcd's Avatar
Unless you have changed your crank, rods, pistons, etc your going to drop a rod or something. 10K takes some work even on a b18c motor.
Old Sep 28, 2004 | 11:24 AM
LSvtec03's Avatar
lsvtec page
maybe that should be a sticky
Old Sep 28, 2004 | 09:01 PM
g2lsv's Avatar
its fukin vtec, not v-tech, or vtech, or v-tec, its VTEC!!!
Old Sep 29, 2004 | 01:03 PM
Default Re: (g2lsv)
yeah the crank and everything was redone but im not saying im going to turn 10k
dame-ningen
24
Jun 15, 2009 07:08 PM
whoneedzvtec
Sep 7, 2007 05:23 PM
weezie
Dec 3, 2004 05:13 PM
Quiz
Sep 26, 2002 05:47 PM
Brian_92GSR
Aug 27, 2002 01:25 PM
