clutch pressure problem
Old Sep 23, 2004 | 06:54 AM
LOC714's Avatar
Default clutch pressure problem
i just installed a new master and slave. bleed it. everything worked fine for the last day or two. now it seems the distance of stepping down on the clutch pedal is so much further. it's like a full swing! i double checked, but no leaks yet...do you guys have any suggestions?
thanks!
Old Sep 23, 2004 | 07:04 AM
99_SH's Avatar
Default Re: clutch pressure problem (LOC714)
The travel of the clutch pedal is the same. You could make some adjustments to the master cylinder and pedal from under the pedal assembly.
Old Sep 23, 2004 | 07:07 AM
LOC714's Avatar
Default Re: clutch pressure problem (99_SH)
but is it normal for the clutch pedal to feel different a few days after installing it. before it felt short and softer. now it is harder and longer.
Old Sep 23, 2004 | 07:34 AM
99_SH's Avatar
Looks like you installed an aftermarket cluch. Yes it is going to be stiffer, but the throw is the same. The pedal only goes as far to the floorboard. So I dont understand how its "longer"
Old Sep 23, 2004 | 07:46 AM
LOC714's Avatar
sorry. to explain this further, my clutch pedal ususally pulls back about 4 inches or so until the clutch grabs in. now the clutch pedal seems to pull back even further, like 6 inches or so until the clutch grips. so in result there is a little stall between shift when before there wasnt.
Old Sep 23, 2004 | 08:10 AM
99_SH's Avatar
OK, that makes more sence. Yes you need to do a clutch adjustment. I usually do this after installing an aftermarket clutch. You will be able to shift the engagement point much closer to the floor.
Old Sep 23, 2004 | 08:20 AM
LOC714's Avatar
ill try that out. thanks man.
Old Sep 23, 2004 | 10:41 AM
Greyout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LOC714 &raquo;</TD></TR><TR><TD CLASS="quote"> before it felt short and softer. now it is harder and longer.</TD></TR></TABLE>
your parents should have explained this to you when you were younger
Old Sep 23, 2004 | 10:47 AM
99_SH's Avatar
Default Re: clutch pressure problem (Greyout)
ROFL!!
Old Sep 23, 2004 | 12:27 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">
your parents should have explained this to you when you were younger</TD></TR></TABLE>
buhahahaha
Old Sep 23, 2004 | 12:34 PM
uncle's Avatar
LMAO!
Jcd5
Transmission & Drivetrain
Jul 24, 2014 11:40 AM
skhell
Jun 23, 2010 12:11 AM
veilsides2000
Honda S2000
Jan 30, 2009 02:20 PM
blkgsr03
14
Sep 16, 2004 05:19 AM
MrSmith
Sep 28, 2001 08:30 PM
