h22 sputtering at low rpm
Old Sep 22, 2004 | 08:13 PM
eric416's Avatar
Default h22 sputtering at low rpm
i have an h22 in a 1993 si. Recently when im at about 2,000 rpm and slam the gas in any gear, the car sputters and there is no power but then a second or 2 later it will take off like its supposed to. Also going into 1st it does the same thing at low rpm. any ideas what it could be?
Old Sep 23, 2004 | 01:28 AM
@ries's Avatar
Default Re: h22 sputtering at low rpm (eric416)
Any CEL's? Check the sparkplugs and cap & rotor.
Old Sep 23, 2004 | 06:59 AM
99_SH's Avatar
I have the same problem. Something tells me its either the ignitor or the knock sensor.
Old Sep 23, 2004 | 02:13 PM
eric416's Avatar
Default Re: h22 sputtering at low rpm (99_SH)
im not showing a cel. it started happening right after i was teaching someone to drive stick. they stalled horribly and jerked the car a lot and reved it high a few times. i dont see how that can cause the problem though
Old Sep 23, 2004 | 06:37 PM
psilo's Avatar
Mine does same thing especially after rough clutch engagement
it sucks.
bookmarking this thread, because i have a feeling its not the knock sensor if yours indeed is related to the kid being rough on your clutch.
Old Sep 23, 2004 | 06:51 PM
nuro's Avatar
Default Re: h22 sputtering at low rpm (psilo)
had a sputtering problem at WOT on a friends car. plug wires were the culprit.
Old Sep 23, 2004 | 08:18 PM
A_Viglakis's Avatar
a lean mixture can cause a hesitation when you go quickly into WOT, backprobe your o2 sensor, you might find a problem. I can't help you on specs. Though a rule of thumb is .40 volts and below is lean .45 volts and above is rich.
Elleray
Oct 23, 2009 10:21 PM
wheelmaneg6
Oct 13, 2006 06:44 PM
92vteclude
Feb 21, 2006 06:27 PM
lak8
Oct 6, 2005 05:03 PM
H22AEG2
14
May 30, 2005 01:08 PM
