b16 as of 9-22
Old Sep 22, 2004 | 07:20 PM
1991hondahead's Avatar
Default b16 as of 9-22
Ok so Far I have cleaned the head and block (thanks everyone for the tips). I have installed the new Bullfrog Cams, Venom Cam Gears, and my new Valve Cover. As far as the block goes I am still stuck on the piston thing. Should I stay stock or change them for higher compersion ratios? I am not going with a turbo so I am going n/a. I need to know what compersion ratio I should shoot for and what type of pistons should I use.
P.S. I don't want to have to sleeve my block I am staying with standard size.
Old Sep 22, 2004 | 07:34 PM
benhatch101's Avatar
hmmm how fast you wanna go, n how much money you wanna spend
Old Sep 22, 2004 | 07:49 PM
Default Re: (benhatch101)
Well I want to be able to kick some domestic chevy sunfire bitch ***. Money it is kinda a problem but I would sell me kidney to make my car FAST. In other words just give me a 2 options. moderate, and expenisve
Old Sep 22, 2004 | 07:50 PM
eda6's Avatar
Just get a b18 now. It's a little more upfront, but cheaper in the long run.
No replacement for displacement.
Old Sep 22, 2004 | 07:52 PM
Malgerus's Avatar
Default Re: (eda6 hb)
A stock B16 running on 3 should beat a sunfire
Anyways, look into some CTR pistons. Should be relatively economical and put your compression in the 11:1 range. Or some USDM Type R if you want new ones, but I think the compression will be lower. Try a search
Old Sep 23, 2004 | 04:54 AM
StorminMatt's Avatar
Default Re: (Mr. S)
Another factor to consider when determining what compression to go with is what kind (octane rating) of fuel you have easy access to and/or are willing to pay for.
Da9jetfighter
Apr 19, 2017 01:30 PM
Cheez-It
Jul 19, 2006 04:32 PM
please.laugh
Sep 24, 2004 09:42 AM
hondapro_2005
Jan 9, 2004 09:23 AM
SpdFrk
Aug 29, 2003 07:42 AM
