- 2005 CRV Problems Help
- 1G CRV question about intermittent rear wipers
- 04 MDX Headlights/ Taillights on a 01?
- Vote: Gen1 CRV...hood/roof/wing
- CRV - No light in meter NEEDLES and Drive "D"
- LX Fabric?
- 2006 Honda Pilot EX 4wd - VTM-4 ON and P0175 - HELP!
- honda element or crv brush guard.
- Pics of Clean/Modded RDX's
- CRV 2003 Front Disc conversion
- Help with Oddy 97 - misfire on all 4 code, rough idle
- airbag question. 97 crv
- What would be a good offer for this CRV
- headlights on a odyssey
- How many kms per tank in a 05 CRV?
- 1999 Honda CRV. How do I replace the interior door handle?
- Transmission HELP!
- 2004 CRV Radio question
- 2002 P1298 and P0420 Codes
- ♠ RDX Discussion ♠
- Transmission issues in 2002 Odyssey
- Noise & Black Smoke from under the hood...
- 1997 honda crv oil pan torque specs
- Crashwagon (AkA Jwood70's '00 V)
- ANY IDEAS ON A INTAKE FOR 07 CRV???
- My wifes 07 CRV added pink 20000K HID'S Today
- Transmission Cooler built in the radiator???
- 2004 Pilot Heater Problem
- Cold Feet in '08 Touring
- cooling problem
- SRS Module repair?
- what motor is in the odyssey?
- Question on 97 Crv Keyless Entry System
- 03 honda pilot transmission issues
- 04 honda pilot
- 99 passport a/t cable
- Immobilizer in Gen1? What years did it come with?
- how would i go about troubleshooting a crv's alarm/remote locks
- gen.1 steering wheel
- Trans "shuddering" on '05 Ody
- Honda Shuttle/Odyssey
- 06 Pilot EX Engine Noise
- Odyssey awd conversion
- 2008 element intermittantly stalls
- Got a 97' Odyssey question...
- 2004 Pilot Question
- lowering springs for 2nd gen crv
- Battery replacement, now several dash lights stay on
- Odyssey suspension fix, Part II; Increasing travel
- Tired of blowing upper ball-joints in your slammed Odyssey?
- FS: 97-01 CR-V EDM front bumper-brand new & oem fog light switch
- 04 odisey trans gone bad any other traini for it?
- H22 into 01 CRV
- 2003 CRV Fuel neck question
- Mixed messages about 2004 Pilot Transmission
- 02 honda crv clutch problem
- PIN code help
- Anyone ever turbo an Odyssey?
- Honda Odyssey won't change gears
- head removal on 95 passport
- my 06 honda powered saturn vue redline
- Honda Odyssey 2006 - Mirror Housing Set Right Side
- No more manual tranny for 2010 Element
- 99 CRV air intake chamber
- Finally Lowered! RA1 tucking stock tire LOL
- F/S OEM CR-V rims cheap $100
- 2002 CRV EX AWD - Please help me determine if it's a lemon!!!
- 2005 Odyssey - Drivers side heat does not work
- CRV Needs a few more reliable HP
- 03 Element "Starter" Delay
- CD stuck in honda pilot
- 99 CRV steering vibrhakingation
- 98 Crv bad engine miss
- 1998 Honda CRV issue dying...
- Stock JDM F22swap /Honda Oddy 97 mysterious misfire
- Wheel Offset
- 05 Odyessy valve ajustment
- 2007 Honda Pilot + iPod Install
- Trick to replacing the turn signal bulb on a 96 Odyssey
- 2001 Honda Odyssey LX
- 1998 Honda CRV
- 2001 Odyssey - Won't start - light relays are clicking incessently
- 99 Honda Odyssey code p1491 and transmission shift rough
- Honda Odyssey 2006 - Heated Mirror Only (Right Side) *USED*
- Honda Pilot 04 control arm ball joint fronleft lower
- RE. 05 honda odyssey malfunction indicator..
- just got me an 06 pilot EX-L
- water on passenger side
- Honda Odyssey 2009 Touring
- 01 van cel
- 05 honda odyssey malfunction indicator..
- 05 honda odyssey malfunction indicator lamp...
- Amsoil ATF vs Honda ATFZ-1
- Salvage Ridgeline project?
- b20 cams
- bull bar for ridgeline will it fit the pilot?
- wierd idling
- Help removing door on crv
- CRV wont start 100% when it rains
- turbo crv?
- No gas gauge and Check engine light on.
- Getting to radio antenna (01 Odyssey)
- honda odessy idea
- 2000 Odyssey rear drums squealing!!
- 2002 Odyssey Parking Brake
- 2001 Odyssey catalytic conveter
- 2001 honda crv turning noise
- Turbo Element
- 2006 Pilot Trans Questions
- 2005 Odyssey rear brake rotor will not come off...
- 99 CRV troubles...B20. plz read/help :)
- 2000 Odyssey cabin lights blinking help!!
- 2000 Odyssey Cold Start
- Longer Driver's Seat rails on 2001 CR-V?
- 99 odyssey transmission ?
- 07 TL front caliper on 03 mdx
- Honda Pilot (03) Timing Belt & Water Pump
- Does Pilot have SS exhuast?
- 2003 CRV lower ball joints
- 2001 Acura MDX
- New CRV owner.. 99 AWD 5sp
- iPod retrofit in 09 Pilot
- flashing asc button on Honda CRV 01
- 2000 Odyssey - Stereo/Navi/Lighter Not Working
- distorted subwoofer: 2006 Pilot EX-L
- Honda ??
- Input please
- 03 Odyssey Vapor Cannister. Where is it?
- 04 Pilot EX Weird engine sound
- CRV Hitch
- j series in a 97-01 crv?
- accord auto tranny to odysses?
- what are the diffs between 01-03 mdx and 04-06
- 3" lift kit available for the Element
- Spreen Honda Meet Sept.12th
- Early Ody PERCENTAGE transmission replaced
- Element (K24) Valve Cover Bolt Sequence
- Lowering Springs/Coilovers for 95-97 Odyssey?
- 98 crv needs new cat in seattle
- Problem with heat - 2006 Pilot
- Help! '97 CR-V Auto Box - How to Remove 1st Clutch Assembly
- Complete Repair Manual for 1997-01 CR-V
- Need Help!! Im on vacation
- 99 Odyssey lowering springs
- Where is the AC diode on 97 odyssey?
- Front Door Lock Solonoids not working
- Door-only-key used for ignition
- 98 CRV 2WD Auto transmission questions
- oxygen sensor wiring
- 04 odyssey a/c just stopped
- unknown dash light
- 01 CRV rear brakes
- k20a intake manifold on k24a1 cr-v?
- Timing marks on CRV
- Brake bleed steps
- dinging with no key in ignition
- Traded Civic for an X3!
- Receded exhaust valves on 99 CRV 2.0 - Is this normal or did I buy an inferior engine
- 2002 Passport Died Wont Start
- trans issues!!!!!
- 1999 Odyssey - runs hot on inclines
- Might need new motor. Can 99-00 work in 98?
- preoiler kit / oil cooler kit for CR-V
- Need motor, someone help on jdm b20b into crv!!
- Looking to buy 1999 CRV. what to look for...
- type r swap... crv?
- 2001 CRV - General Questions/Thoughts
- 2006 CRV SE showing ODB2 "Not Ready"
- 2006 Pilot Towing Questions (searched)
- Towing with a 97 odyssey
- Just picked up my first beater crv, overheated now trying to figure out damage.
- 97-01 CRV UK front bumper, who wants it?
- check this out!
- 2000 Odyssey - Brakes
- Replacing complete A/C system: Oil question
- Correct Part Name - Odyssey 2000
- DVD Screen Dims with Headlights On
- A/C Fan Squeak
- 03 Odyssey code 0505 and 1129
- 1st gen crv lip ....... SOME ONE PLEASE help identify
- Is the B20 crank the same as a B18B1?
- 2009 CRV - Best HID solution?
- 2009 CRV - Replacing console or adjusting armrest
- MDX questions
- Best strut shock replacements 2003 Odyssey
- 2000 CR-V MT EX - problem with ODBII port / ECM
- 2000 CRV A/C Evaporator leak
- 2000 CRV AWD?
- 2006 CRV SE-no way to connect ipod???
- crv idle surges when in park
- what should a stock b20b compression test read
- Full on rock buggy
- 2004 CRV - Alternator Upgrade
- Fast Idle when Cold.
- 99 CRV SRS light airbag replacement questions
- 1st Gen CRV 5 lug to 4 lug...
- crv immobiliser
- 01 CRV seatbelts...
- '01 Odyssey running crappy after pulling trailer
- Considering Element purchase
- Civic Suspension on CRV?
- honda pilot radio diagram
- Question for you baby-daddies/mommies with Honda Elements
- 2003 Honda CRV, P1259, P1166, HELP
- Check Engine Light Question - How to turn off
- Odyssey CFK fix?
- 1999 CR-V overheating, help?
- 2002 TL-S rims on 08 Odyssey?
- 2004 Pilot AC pressure readings
- Speed Sensor
- 1998 odyssey distributor
- 2005 Odyssey Left Power Door Issue
- headlights dim when you let off the gas
- 2006 CRV Evap Canister Replacement
- RDX ECU information
- Honda Ridgeline RTL MAJOR WIRING ISSUE...PLZ HELP!
- power window question.......PLEASE Look!
- 2002 Odyssey Transmission Problem
- 99 CRV engine load issue with air on
- 2006 Ridgeline switch to synthetic oil?
- Question about adding a custom subwoofer without replacing the OEM deck
- 2001 MDX Brake Question
- 2005 CRV Maintenance Message Light.
- Alignment problem - how to tell?
- 2006 odyssey shocks
- CRV Power Door Lock Problem
- 2004 crv lx awd running boards
- 04' odyssey weird brake pull... honda tech needed
- Need Toyota HELP...I know its HT...but you guys are smart!
- Replacing purge control solenoid valve and evap canister
- 2000 Odssey running lights
- 1997 Honda Passport question!?
- 'D' light went out
- Odyssey question
- location of obd2 connector to hook up scan tool for 2001 crv
- pics of grille guards and bull bars on CR-V
- 2008 Element SC Fog Lamp Bulb Type?
- Misfire
- Thinking of picking up this Odyssey
- Towing Questions
- Help: 2001 Honda Odyssey Struts
- 2001 CRV Idle issue resolved
- 2nd gen antenna
- Project CRV PIC's Added
- gen 1 crv problem
- Has anyone done this with a 98 Ody ?
- clutch question????
- odysey 96
- 2000 Odyssey trany rebuild kit
- exhaust for 98 prelude sh
