PDA
View Full Version : Honda Minivans, Crossovers, and Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16
  1. b20b will not idle
  2. Where can I find a good, low-miles used, engine for a 95 Honda Odyssey in NW Florida?
  3. How can I find year of motor on b20b?
  4. Jumper cables hooked up backwards... Honda Pilot.
  5. crv motor change help
  6. Last gr8 in 08 meet
  7. 2003 CRV variable timing control question
  8. '01 cr-v wont start
  9. passport wont start
  10. Master Window switch problem 2005 Pilot
  11. Honda oddyssey, good, bad, good year to get, stuff to watch out for?
  12. how to identify b20z camshafts
  13. mechanic recommendation?
  14. 1st Generation CR-V owners...
  15. Valves adjusted - 1999 CR-V - Still no help
  16. 2003 mdx shop manual
  17. 1999 Honda CR-V Check Engine
  18. looking to buy the 1nd gen crv(maybe 2nd gen)
  19. Water leak into driver side compartment
  20. need crv part number
  21. Back up camera replacement. Where to find one?
  22. Pilot have VIN decals on inner fender lip?
  23. transmission problem
  24. CRV floormats?
  25. 1st gen. CRV owners.... what goes where?
  26. Stabilizer Busings on my E.
  27. what options are available for the 1st gen CRV?
  28. 2008 Pilot electronics (TPMS, VSA)?
  29. 1995 Honda Passport - Key will not turn in ignition
  30. MDX Idle issue
  31. 2003 CRV shimies only under acceleration
  32. some Pilot questions
  33. Towing experiences with a '98 CRV Auto?
  34. Welcome me! new crv owner!
  35. tire life on your 07-08 mdx
  36. 2000 CRV Shift Map?
  37. 98 CRV DIES on HWY....HELP!
  38. CR V 2007
  39. Honda Pilot Picture Thread!
  40. 2nd Gen CR-V 6-Speed
  41. CRV... Dropped 2MPG
  42. Rsx intake into an 03 auto Element?
  43. stereo problem?
  44. 2002 CR-V Maintenance Questions
  45. Stolen Element cats
  46. CRV Pic thread?
  47. My thermometer's stuck!
  48. Honda CRV -- dead battery, doors won't open even manually!
  49. Element Owners
  50. Key to Honda CRV
  51. 1999 Honda CRV Car Seat Dilemma
  52. Ordered new "toys" today
  53. Honda Element wallpaper
  54. Wheel Bearings on a 1998 4WD CR-V
  55. Im in the market for a small SUV. haven't a clue where to start!
  56. 2001 Odyssey: Can it be swapped to manual?
  57. The new Pilot
  58. CRV Gen 1 DIY Hood Dampeners
  59. Dash light issue......
  60. 98 CRV 2 WD Auto Trans issue
  61. TEIN TYPE WAGON COILOVER
  62. 98 Crv brake light on
  63. PLEASE ATT. ALL OWNER HONDA RIGEDLINE RTL MODEL...
  64. '02 CRV Rear Brake Issues???
  65. b20z??
  66. Random pics from a small Element meet
  67. Odyseey ever 3.0 V6?
  68. Spare Tire Load
  69. supercharging a b20b
  70. Element HID Installation Question
  71. everything is going wrong?
  72. Test Pipe
  73. 2005 Pilot Rough Shifting
  74. where can i buy a B20 head?
  75. 2001 CRV rough idle....
  76. 2008 element oil change
  77. Passport/Rodeo Engine
  78. Ridgeline Bed....
  79. eighteens on crv
  80. ELEMENT LIFT FOUND
  81. Seat Belt beep for MDX !help me!
  82. LIFT KIT????
  83. 06 odyssey scheduled maintenance ?'s...
  84. CRV Throdle sensor issues
  85. 98 CRV rear diff possibly going bad?
  86. 1998 honda crv
  87. RDX SWAP INTO AN ELEMENT
  88. 99 odyssey
  89. MDX Torque Converter
  90. Looking for wheels for 2000 CRV
  91. KSport Kontrol Pro's for ELEMENT !!
  92. Brake(s) line is leaking
  93. 2007 Pilot Navigation
  94. Differences between 2006 and 2007 CRV??
  95. possible?
  96. headlight cleaning
  97. 01 CRV-shifting issue. Please help
  98. 06 CRV
  99. '97CR-V overheat:
  100. Question for Element owners, does opening the back door become annoying?
  101. 07 CRV Intermittent Check Engine Light
  102. Touch Up Paint For Left Passenger Door
  103. FS:2007-2008 CR-V JDM OEM INTERIOR ILLUMINATION KIT
  104. WTB: Honeycomb grille for crv 02
  105. Anyone with increased HP on an 1st gen AUTO CRV?
  106. Acura Front Underbody Spoiler installed
  107. Honda Stream!
  108. 2008 Element Safety Recall
  109. srs light
  110. CR-V 2003 nothing on the AC works? Any ideas.
  111. FS: Acura RDX Front Underbody Spoiler...white.
  112. 2000 cr-v won't start
  113. 2004 CRX parts shared?
  114. 2001-2005 Mdx Tail light question. Are the 05 Lights interchangable with the 01?
  115. 2003 CR-V fix for no blower motor (fan)
  116. 07 CRV window problems after tint
  117. 96 Odyssey ball joint came apart while driving. HELP
  118. 2002 honda crv failed inspections for emissions
  119. 96 Passport Question
  120. 1997 honda crv for sale, MD
  121. Pic Request: 07-08 CRV radiator hose...
  122. REVERSE LIGHTS PROBLEM
  123. h22 crv.
  124. 2003 CR-V code P1166
  125. tuning my 1997 honda crv
  126. Ridgeline with all black interior?
  127. No Main Brake Lights
  128. 2003 CRV AC quit suddenly
  129. turbo kit on my crv worth it? and some good suspension
  130. 95 integra front wheel bearing removal?
  131. 275/40/20 on my 08 RDX
  132. 2000 honda pilot no start
  133. parts for honda crv
  134. Help!!!! Need timing belt diagram for 2000 Honda Pasport ASAP!!!!!!!!!!
  135. size rims and tires.
  136. rusty calipers
  137. Please help, coolant leak into the engine? Odyssey
  138. Crankshaft Speed Fluctuation Sensor ('99 CRV)
  139. F/S 4300k h11 55w hid kit
  140. F/S 4300k 55w HID H11 kit
  141. need help on A/c with my 95 odyssey
  142. Forged Wheels for My 2008 MDX
  143. Odyssey 2002 Tranny filler plug unusual
  144. 03 Honda Odyssey offset question
  145. CRV air conditioning problems/broken
  146. Honda Pilot rear differential question
  147. 2002 CRV Code PO420
  148. Can I add a outside temp guage on a 2008 CRV LX?
  149. How do I check a CEL on a 04 CRV?
  150. 4P connector problem, can't remove terminal for test
  151. crv diff problems
  152. Let's talk RDX
  153. friends stolen element
  154. 4wd in honda crv
  155. 2000 CRV low compression in #1
  156. 03 pilot 60k major tune
  157. 1995 b20b short block with b20b obd1 oil pump questions.
  158. 5w20 or 5w30 oil
  159. remote starter
  160. What exhausts fit a 97+ honda crv?
  161. Hitch for the Element....Free shipping!!!
  162. My 07 Odyssey
  163. What Tow Hitch for my 97 CRV?
  164. crv suspension question
  165. whats a good way to get more hp for my crv?
  166. need engine swap suggestions
  167. 5 speed. searched
  168. NRG Hood damper installed on my E
  169. Odessy Drl Relay
  170. LSD/locker on CRV
  171. lift on CRV?
  172. Ridgeline Ipod hookup..questions.
  173. Buying a second hand CR-V - What questions should I ask??
  174. possible?
  175. crv wont start
  176. Rattle from under the hood when start 2000 CRV
  177. where is the a/c compressor clutch relay???
  178. 97 honda crv
  179. 2001 CRV Tire size
  180. 98 crv headllight bulb
  181. Element Grill
  182. tow package for a rigdeline
  183. Brand New CRV
  184. EK coilovers on a 2000 CRV?
  185. First Gen CRV: KSPORT COILOVER INSTALL (LOTS OF PICS)
  186. The E and the Si
  187. Honda CRV Seatbelts...
  188. XM Radio for Ridgeline
  189. 2003 Pilot Knocking Noise
  190. any problems with slamming an allwheel drive crv?
  191. Honda Pilot real Miles per Tank
  192. TRACKING DEVICE????
  193. test
  194. looking for ipod cable for pilot 06
  195. Changing Front Struts??
  196. 2003 - P0172 and P0175
  197. Want to lower my CR-V
  198. First drive - 2009 Honda Pilot
  199. 97 CRV rear storage capacity
  200. 96-01 CRV transmissions A.T 4x2 VS A.T. 4x4
  201. where to find crv passenger door
  202. Looking for a tranny
  203. CRV engine mount question
  204. Ridgeline style key for Element?
  205. element vtec
  206. ridgeline has same frame as the van?
  207. Key ?
  208. What octane gas can we use?
  209. Pop up camper add-on for the Element...cool stuff
  210. would swapping smaller engine into crv better mpg?
  211. Odyssey power seats not reclining
  212. 02 Honda Odyssey Questions
  213. Any Ridgeline owners take their Trucks offroading?
  214. manifold vaccuum port on 00 Odyssey EX
  215. Odyssey seating issue
  216. SC Center console install "How-To". Anybody have one?
  217. 2004 Element
  218. Odyssey Manual Online?
  219. element radio ?
  220. header for crv same?
  221. head swap on crv
  222. Honda CR-V Jackson Racing Supercharger
  223. Clicking toward rear = propeller shaft?
  224. Bit the bullet. Got myself a shoe box
  225. NEED AIRBOX FOR 2002 ODYSSEY
  226. A Different Kind Of Noise From A CRV (please help, searched)
  227. broken u-joint 99 crv (front end of propeller shaft)
  228. How much did you pay?
  229. what size of rims can be put on a 02 mdx?
  230. Tough to get out of park 1997 CRV Automatic
  231. visor
  232. 01 CRV 4wd transmission trouble
  233. 1st gen rear disc brake swap???? Anyone have info?
  234. water pump replacement on 2000 crv
  235. 2002 CRV Radiator Fan/A-C Fan Identification?
  236. crv transmission
  237. Torque specs on differential drain and fill plugs for '07?
  238. 1st gen crv awd question????
  239. HID's in CRV's!!!
  240. Longshot: Need dimensions of Manual transmission
  241. 04 honda element dashboard light change
  242. steering wheel shaking at highway speeds???
  243. Free CRV transmission...Stockton, CA
  244. k20 swapped 1st gen crv
  245. Current Element problems/annoyances. Any rumors on the 09s?
  246. engine and trans swap
  247. what is the high hp could ur tranny hold?
  248. maintenance light.
  249. crv engine question
  250. changing tail lights
