Crank Fluctuation Sensor Wiring Clip
Doing a timing belt change on my 00 EM1, and the CKF sensor at the crank pulley has wiring that snakes up tight against the timing belt cover, held in place with a metal clip thats bolted to the oil pump. My clip is corroded through and honda no longer makes the clip 32756-P72-A00. Without it, the wire is going to get shredded by the alternator belt. Has anyone else seen this and found an alternate? I may resort to fabricating my own, but would be curious if anyone else found an easier way.
Re: Crank Fluctuation Sensor Wiring Clip
Try reverse searching this number, to see what other cars had this same bracket.
You could probably source one off Ebay, or even amazon, if not a local salvage yard will probably have a honda with one.
This is not an item that needs to be new. Its just locating a sensor.
Yeah, i've actually done all of that. My best bet might be finding one at the Carlisle Import Nationals in may.
I have no problem finding a 3rd party sensor (honda doesnt even make the CKF sensor anymore), but it doesnt come with this clip. I thought the clip might come with oil pumps, but no luck there either.
If anyone knows the best place to search for parted out honda engines let me know.
The part number 32756-P72-A00 also fits:
2001......Honda.....CR-V................EX, LX, SE......2.0L L4 - Gas
2000......Honda.....CR-V................EX, LX, SE......2.0L L4 - Gas
2000......Honda.....Civic................Si....... ..........1.6L L4 - Gas
1999......Honda.....CR-V................EX, LX............2.0L L4 - Gas
1999......Honda.....Civic................Si....... ..........1.6L L4 - Gas
1998......Honda.....CR-V................EX, LX............2.0L L4 - Gas
1997......Honda.....CR-V................LX..................2.0L L4 - Gas
1997......Honda.....Civic del Sol......VTEC.............1.6L L4 - Gas
1996......Honda.....Civic del Sol......VTEC.............1.6L L4 - Gas
