98 Civic dx tachometer is jumpy
Old 07-16-2019, 05:44 PM
Cody92's Avatar
Default 98 Civic dx tachometer is jumpy
Hey everyone I'm a new member looking for some good advice on an issue IV been fumbling with. I own a 1998 Honda Civic DX and have gone through the cat getting it all up to date. Iv replaced the entire distributor, alternator, tss , struts, and recently a new gauge cluster to add a tachometer to the bare gauges my dx came with. My problem now is that the tach IV newly acquired is jumpy and works correctly 30% of the time. I'm assuming this is an electrical issue but iv already replaced the distributor so that leaves in between somewhere? Hoping someone else has had this issue. I was told the gauge swap was simply plug and play. Thanks everyone.
Old 07-16-2019, 06:03 PM
Cody92's Avatar
Default Re: 98 Civic dx tachometer is jumpy
I should also add that it doesn't seem to effect the way the car runs.
Old 07-16-2019, 06:42 PM
muellersfan's Avatar
The tach itself may be the problem.
Old 07-16-2019, 07:16 PM
Cody92's Avatar
Is there a way to test it without another tach to swap in? I just bought it from what I thought was a trusted seller. It was supposedly tested before shipping to me. $100 down the drain possibly.
Old 07-16-2019, 07:41 PM
Sellers lie. You can return it for a refund.
Amazon sells gadgets that read rpm.
Many OBD2 code readers read live data, such as engine rpms. Maybe you have a friend who has one?
If you lived in Houston, I'd lone you mine.
Old 07-16-2019, 08:16 PM
Cody92's Avatar
I have a mechanic that could hook up to it, he didn't wanna drive into the wiring. Oddly enough it worked perfect on my way home for lunch break just now. Grounds possibly?
Old 07-16-2019, 09:24 PM
^Let him.
If when the tach is jumpy, the code reader is steady, you have your answer.
Any CEL codes?
Old 07-16-2019, 09:28 PM
Cody92's Avatar
Originally Posted by muellersfan
^Let him.
Any CEL codes?
Negative on the cel codes. A bare wire or something along those lines wouldn't cause it working fine sometimes and most times not? I appreciate the input btw guys this is very helpful 😊.
Old 07-17-2019, 12:05 PM
Cody92's Avatar
Well I got another cluster to swap the tach from and it's doing the exact same things and I'm about to give up on this because I'm not electricaly skilled.
Old 07-17-2019, 02:25 PM
Does the CEL work or did you hook up a code reader?
Old 07-17-2019, 02:27 PM
Cody92's Avatar
CEL does work, it's been hooked up and I just got done clearing a crankshaft position code through an entire distributor replacement. Car had the wrong distributor when I bought it. Runs smooth now.
Old 07-17-2019, 02:35 PM
As an experiment, run a fresh new tach wire from the ICM to the cluster to see if the problem is eliminated.
smeags
39
05-13-2013 08:43 PM
2000_CivicDX
40
11-10-2005 07:44 PM
98CPEcivic
08-08-2005 07:02 PM
kappy
09-05-2001 07:32 AM
Quick Reply: 98 Civic dx tachometer is jumpy
