98 Civic dx tachometer is jumpy
Hey everyone I'm a new member looking for some good advice on an issue IV been fumbling with. I own a 1998 Honda Civic DX and have gone through the cat getting it all up to date. Iv replaced the entire distributor, alternator, tss , struts, and recently a new gauge cluster to add a tachometer to the bare gauges my dx came with. My problem now is that the tach IV newly acquired is jumpy and works correctly 30% of the time. I'm assuming this is an electrical issue but iv already replaced the distributor so that leaves in between somewhere? Hoping someone else has had this issue. I was told the gauge swap was simply plug and play. Thanks everyone.
Re: 98 Civic dx tachometer is jumpy
The tach itself may be the problem.
Is there a way to test it without another tach to swap in? I just bought it from what I thought was a trusted seller. It was supposedly tested before shipping to me. $100 down the drain possibly.
Amazon sells gadgets that read rpm.
Many OBD2 code readers read live data, such as engine rpms. Maybe you have a friend who has one?
If you lived in Houston, I'd lone you mine.
I have a mechanic that could hook up to it, he didn't wanna drive into the wiring. Oddly enough it worked perfect on my way home for lunch break just now. Grounds possibly?
Negative on the cel codes. A bare wire or something along those lines wouldn't cause it working fine sometimes and most times not? I appreciate the input btw guys this is very helpful 😊.
Well I got another cluster to swap the tach from and it's doing the exact same things and I'm about to give up on this because I'm not electricaly skilled.
As an experiment, run a fresh new tach wire from the ICM to the cluster to see if the problem is eliminated.
