Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
Old 04-24-2019, 07:08 AM
miggy23's Avatar
Default Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
Okay so I bought this ecu from a guy for $100 said it was chipped and tuned on crome. But this **** looks stock to me I'm not an expert on ecus by any means but I don't see any difference from a stock p75 to this one. Any help would be appreciated.
miggy23 is offline
Old 04-24-2019, 07:48 PM
spAdam's Avatar
Default re: Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
Stock. Bad news, your friend is full of it. Good news, no one fucked it up yet so it’s a good candidate for an S300 install. Solder away.
spAdam is offline
Old 04-24-2019, 08:27 PM
JRCivic1's Avatar
Not chipped... not tuned on CRomE. Stock... and still worth a Hondo.
JRCivic1 is offline
Old 04-25-2019, 06:13 AM
miggy23's Avatar
Okay thanks so I talked to him and he said that he was overseas serving our great country. When he came back he took it to a shop and said they tuned it he said he wasnt sure if it was remapped or chipped but I never even knew you could remap the ecu without chipping it. Did the tune shop he went to bs him?
miggy23 is offline
Old 04-25-2019, 06:20 AM
spAdam's Avatar
You can't. It's a stock ecu. Doesn't matter anyway, if it was tuned is his car it wouldn't be in your car, unless you got his engine too.
spAdam is offline
Old 04-25-2019, 07:21 AM
miggy23's Avatar
Yep I got the engine as well b20b built head cams, valve spring, retainers he said it pulled hard
miggy23 is offline
Old 04-26-2019, 11:45 AM
O.G. triple O.G.
NVturbo's Avatar
I wouldn't even trust one word he says. Might want to do a compression test on the swap prior to install. Saves you the headache.
NVturbo is offline
so simple
04-12-2009 08:31 PM
MrEG6er21
12-27-2004 04:36 PM
TRuST
01-18-2002 04:03 AM
Quick Reply: Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
