EH2 Fuel gauge
Old 12-13-2018, 06:37 PM
wurmhole's Avatar
Default EH2 Fuel gauge
1992 eh2 hatch cx. My fuel gauge used to read half full at full tank. This was indicative of a bad sending unit so i replaced it. now my gauge stays at empty and my swnding unit reads 0-5 ohms. I have read all posts but none have my problem. I noticed the 3p connector has wires only in the middle and left side, and it looks like my sending unit has leads on the middle and right side. Is there differences in sending units? I took apart my cluster and the gauge seems fine. Thank you for any help.
Old 12-14-2018, 01:07 PM
JRCivic1's Avatar
Default Re: EH2 Fuel gauge
Where did your new fuel level sending unit come from ???
Old 12-14-2018, 08:35 PM
wurmhole's Avatar
Parts geek
Old 12-14-2018, 10:43 PM
wurmhole's Avatar
h
Old 12-15-2018, 12:14 AM
JRCivic1's Avatar
You should try a genuine Honda one.
Old 12-15-2018, 09:36 PM
muellersfan's Avatar
If you ground the Yel/Wht sending unit wire, does the fuel gauge needle rise to Full?
The sending unit is attached to the Yel/Wht wire from the gauge and the Blk/Wht ground wire.
Old 01-20-2019, 12:10 AM
wurmhole's Avatar
Yes, The needle slowly rose from empty to about half and I took the jumper out. I believe I bought a sending unit for a dx civic. I have a cx and it has a lower capacity tank, so maybe the connections are also different. Why is the plug a 3p with only two wires?
Old 01-21-2019, 03:50 PM
wurmhole's Avatar
Bump anyone?
Old 01-22-2019, 05:22 AM
Test whether the fuel sending unit ground wire has continuity with body ground. It should.
Old 01-23-2019, 01:20 PM
BiggieBert's Avatar
because 5g’s in other markest (EDM/JDM) come with low fuel lights, and that third wire is needed then.
Old 01-30-2019, 07:09 PM
Oh look, I can change this
deschlong's Avatar
Icon7 Re: EH2 Fuel gauge
Mred472
10-15-2017 11:00 AM
crex23
12
06-11-2014 12:34 PM
fog raw
06-21-2012 07:08 AM
nmssr08
10-27-2005 03:30 AM
the_crowbar
08-30-2004 09:13 AM
Quick Reply: EH2 Fuel gauge
