Is this a good way to seal the oil pump
Old 04-22-2018, 09:27 AM
89ED's Avatar
Default Is this a good way to seal the oil pump
Is it?
Old 04-22-2018, 11:31 AM
Kramer5702's Avatar
Default Re: Is this a good way to seal the oil pump
They dont come with a gasket? If no gasket is supplied/offered then 9/10 no gasket is needed. I see the O-Ring and if thats all thats available then you dont need the copper sealant.
Old 04-22-2018, 11:56 AM
-Intl Steve Krew
Caoboy's Avatar
No, you need hondabond/rtv.
Old 04-22-2018, 12:57 PM
89ED's Avatar
I suggest using either of these. I didn’t like that the copper spray said it was good for heat transfer.
Old 04-22-2018, 02:19 PM
Kramer5702's Avatar
Only time I used to use copper spray was to hold a gasket in place during installation.
Old 07-08-2018, 09:48 PM
YoungMoney_Twit's Avatar
Can you use the spray and leave the gasket over night and still be good to use?
Old 07-10-2018, 05:41 PM
89ED's Avatar
Don’t use the spray bc it’s designed to transfer heat.
Old 07-10-2018, 09:01 PM
acmoc's Avatar
yep, this stuff. It's what you use on the upper rad hose blok adapter
jlfrnce
09-15-2009 09:07 PM
ketchup
04-19-2008 10:32 PM
acurar0ss
05-18-2005 07:34 AM
DriveSlowHomie
04-01-2005 04:37 AM
Jonathan_ED3
04-11-2003 09:02 PM
Quick Reply: Is this a good way to seal the oil pump
